I think I might have one considering I changed all boost leaks and a faulty DV that I had and It still makes the futtt, futtttt, futtttttttttt on acceleration. I know you need to check it on a cold start and have someone cover the tailpipe to block off the exhaust and force a leak out of where its leaking from but I don't have a lift of any sort and cant get under the car to see if there is a leaking spot. Is there any easier way to check the exhaust system and find out if its leaking. I am also going to check the gaskets but I can only get to the one stating at the turbo since its under the hood. Help?
