Results 1 to 12 of 12
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    need help!!!!don't know what to do
    went to the mechanic this morning and a couple of codes came up
    cylinder #1,2,3,4,5 miss fire
    ....what is the cause of this and how do i fix it?
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Re: need help!!!!don't know what to do
    Changing the spark plugs is a good start. See if that clears up the misfire.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Don't change plugs yet. You most likely have a vacuum leak with that many misfires. Pressure test with soapy water before you spend any money.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    holy shit...can someone make a misfire sticky already?! everyday someone posts "help i have a misfire"...
    no offense to you mmxruffryder!
    but seriously, can someone make a sticky,or even put it in a FAQ somewhere! its the same questions over and over with the exact same responses! misfire= plugs,ICMs,boost/vac leak,coil packs,etc...it wouldnt be a hard sticky to make considering the topic has been discussed 45 times in the past month!
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    ICM, ICM, ICM! Almost 98% for sure it will be one or both of your ICM's. Sit on top of your airbox
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by mmxruffryder15 View Post
    yeah, seriously, you need to search....i've seen you make 34132542345 noob threads. Read the FAQ at the top of the page, and if you have anymore questions, please, search first.
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Mar 28 2008
    new york
    lol i kow i need to search but i'm too lazy...why search when you can just ask and get the answer
    Feb 12 2004
    Orange County, CA
    wow, pretty sad if your too lazy to search.
    2021 C8 RS6
    2006 S4 Avant SOLD
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Is cylinder #6 too cool for school or something?
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by grAh4m View Post
    doesn't let peer pressure get a hold of him
    Feb 09 2007
    Charlotte, NC
    If thats the case, don't expect any help from any of us in the future.....
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by ///M3 TO S4 View Post
    That's an understatement.
