    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    wheel spacer question.
    Offset: 37mm
    Backspacing: 6.26"
    Bolt Pattern: 5-112
    Rec. Tire Size:235/35-19
    Weight: 29.6lbs.
    those are the dimensions of my rims and after dropping the car on bilstein sport/neuspeed race, the inside sidewall of my tire is getting chewed up by my upright or control arms not sure what.
    so my question is what size spacer should i get? i don't wanna go to far out so as to hit the outer fender....., or what other fixes are there to this problem? car has been aligned already right after the drop less than 4 months ago, everything was spec or within spec........
    TIA for any help. i searched but saw a sea of posts about new wheels, and pictures. i need numbers.
    edit: just to throw it out there, i'm only having problems with the front tires.rears are fine.
    car and rims in question....
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Re: wheel spacer question.
    Clean car man, good luck with the spacers.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    id say get it on a lift and verify exactly what is rubbing at maximum steer (lock to lock). possible options include
    Spacers: 10mm would most likely be safe. Make sure to get Hub Centric. H&R's are good.
    Wheel Stop: Must be welded. Will reduce your steering radius. Unsightly if not done properly.
    Notching: grind down the section (of control arm or suspension component) that makes contact with the wheel/tire assembly. Depending on clearance needed, may hinder structural integrity of component.
    And your last option: Let me take those wheels off your hands and ill give you my oem sport package 16's.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Sep 01 2005
    Quote Originally Posted by B5A4Kevin View Post
    i guess i'm just gonna try the 10mm spacers. don't really want to grind away at any of my suspension components and don't really want to do wheel stops.
    and thanx for the offer but i already have sport 16" rims sitting in the garage.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    run 225's isntead of 235's
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
