Results 1 to 15 of 15
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    my center console broke
    the two hinge pieces that hold it on broke wtf
    does anyone know the part number to oder a new on or know some way to fix it?
    Established Member Two Rings Robrich23's Avatar
    Apr 27 2008
    Denver
    Re: my center console broke
    one side of mine broke, dealer said I would need to replace the whole thing. So I thought I'd try and save a few bucks and fix it myself.
    The degree of difficulty will vary depending on where they broke.
    My Solution: (probably not the best but it worked for me)
    JB Weld: I tried super glue and a few other products with no success. JB is the way to go.
    Drill a small hole through the separated hinge into the lid hinge matching them up.
    Use thin wire
    ( i stripped the plastic off a twistie tie) run it through both pieces and twist together, this will allow you to apply the JB with little movement, and prevent you from having to clamp or hold the pieces together while waiting for them to dry.
    Apply JB Weld I applied the JB to the hinge while it was in the console because I could not find a way to put the lid back in without breaking the hinge off again.
    Pat yourself on the back for DIY and saving a few $$
    hope this helps.
    Jun 08 2008
    Calgary AB Canada
    I did almost the same thing but used epoxy. Holding up fine for a few months
    May 21 2007
    Florida
    welcome to my world man. not only does it not latch but one of the legs is broken too. no idea what to do. if you fix it let me know how. dealer quoted me (at my discount) a ridiculous price of about $200 or something along those lines.
    2018 Navarro Blue Q5
    Registered Member One Ring elmexican's Avatar
    Dec 25 2007
    S4.....someday
    California
    Same shit happened to me. WTF! I was hoping I could replace it inexpensively, $200 BUCKS!!!! Wow! I guess I will try epoxy for now.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    are you tyalking glove box or the ash tray???
    Oct 17 2007
    mass
    it was the glove box the piece between the drivers side and passanger seat
    Established Member Two Rings tarzjdm's Avatar
    Jul 15 2007
    B6 1.8t FWd
    san dayGo
    just make an L bracket and screw it down..... it should work! that's how i fixed my glove boX!!
    Oct 17 2007
    mass
    yea i glued it a few weeks ago
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    wtf...............wtf.....wtf.............wtf..... wtf.....wtf.....wtf
    .....wtf.....wtf...............wtf....wtf......... wtf..........wtfwtf
    ..........wtf.......................wtf........... ...wtf.....wtf.....wtf
    .....wtf.....wtf..............wtf................. ..wtfwtf..........wtf
    wtf...............wtf.....wtf..................... ..wtf...............wtf
    mine's rattling too yo :(
    Veteran Member Three Rings Jarim's Avatar
    Nov 28 2008
    N/A
    this just happened to me... tried super glue with no success...
    The wire idea is legit tho... maybe i'll try that. and then JB that sucker.
    B6 A4 1.8t MODS: Custom 3" to dual 2.5" Turboback Exhaust, 034 3" Testpipe, K&N Drop-in, FMIC, Hitachi Coilpacks, 007 Diverter, Neuspeed Snub, RS4 Sway, Custom Interior, Yellow Fogs
    Oct 17 2007
    mass
    yea i glued it twice but i eneded up buying a new one
    you would think that they wouldnt use junky pieces in an expensive car
    b6 a4-sold
    2013 m3
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    My whole center console all the way from the radio to the back seat is messed up, I'm just gonna go for the B7 swap with an Arm rest delete to have cup holders.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Oct 16 2006
    Naperville
    armrest delete? the only person i know who actually doesnt have an armrest nor a hole where the arm rest mounts to is Vinny.dtw Would be nice to see a b7 version of this... i believe John (condo) said that the dealers sell it like that and you actually have to cut it out yourself for the armrest
    Aug 16 2009
    In the OK Corral
    ^^^ Yeah, I heard about it, when I do it is once I get back to the states, so by the time I start doing it someone would probably already beat me to it. The armrest just gets in the way when you're shifting, but I guess I'd miss it in long trips.
