Results 1 to 39 of 39
Thread: Attn: All DBW
    Oct 22 2006
    Attn: All DBW
    Was wondering if anyone has tried that N249 bypass, was just reading about it in b6 forum and wanted to know if the any b5 have done this and with wat type of results
    here is the link for the b6 guys
    http://www.audizine.com/forum/showthread.php?t=231928
    Oct 01 2008
    Philly
    Re: Attn: All DBW
    i just read the B6 post..im gonna try this over the weekend, ill let you know how it goes.
    Senior Member Two Rings 1poynt8tee's Avatar
    Dec 09 2007
    is full of junk.
    San Francisco
    Re: Attn: All DBW
    Hm...kinda wondering about this myself now, one of the nipples was on the verge of breaking when I replaced a hose on the IM. I wonder if this will improve my partial throttle feel.
    Sep 17 2005
    Dublin
    Re: Attn: All DBW
    Yeah I did it. Boost seems to be more resposive to the gas pedal. A less DBW feeling, if you will. Thats about it. The reason I did it was to diagnose a boost issue, and I just kept it that way. So the DV vac line runs straight to the intake mani like on AEB engines, and i jsut looped the n249.
    2000 A4 1.8T
    1997 A4 1.8TQM
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    Re: Attn: All DBW
    there are alot of reads on ripping out alot of the check valves and sytem in the b6 section, keep searching, if you cant find i will find them tomorrow morning
    ::2002 S6
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: Attn: All DBW
    i read the b6 post an im gonna try this. sounds like everyone that did it had a good response.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Attn: All DBW
    I think this is what my friend was talking about in order for my DV fluttering to go away.
    Im a little confused now, what do I do with the intake manifold hole now that used to be connected to the n249?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Re: Attn: All DBW
    Quote Originally Posted by biketsai View Post
    the vacuum line from the intake manifold goes DIRECTLY to the DV. then loop the n249 with some hose, viola. (some say you can leave the n249 without looping it but i would be safe and loop it to keep anything from getting in there.......
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Attn: All DBW
    I'm going to do this also. I want to loop the SAI Solenoid (N112) also at that time and cap off the double t line running to it that feeds the vacuum reservoir. Should simplify some of the vac. lines I have going so that should make my life a little easier when I have to diagnose boost leaks.
    I'm a little worried about the CEL because of the SAI not having the right amount of flow but I figure this way I can give it a shot and its easily reversible for emmisions.
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Quote Originally Posted by boostedup View Post
    Will it be alright if I still have my boost gauge running off of this DV line?
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    K, I just finished, and with the line originally coming from the Intake manifold to the sensor, I just used that hose to loop it. Pretty simple.
    My 5-Speed Swap DIY
    - B6 USP
    Apr 10 2007
    Eastern PA
    Re: Attn: All DBW
    What did you do with the T line that feeds the vac canister?
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Quote Originally Posted by GetBoosted84 View Post
    Nothing. All I did was remove the DV line, and moved that to the front corner intake manifold spot.
    Then removed the hose that was originally on the intake manifold and used that to plug the original spot where the DV line hooked up at.
    does that sound right?
    My 5-Speed Swap DIY
    - B6 USP
    Apr 10 2007
    Eastern PA
    Re: Attn: All DBW
    So you left that T open to atmosphere? That might be a leak considering it connects to the N112 also. I would check by just starting the car and seeing if you feel vacuum from that hole to make sure.
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Ok, I know that there is a hard line (T) that comes off of the valve and is connected to the other valve. I didnt touch that one.
    My 5-Speed Swap DIY
    - B6 USP
    Apr 10 2007
    Eastern PA
    Re: Attn: All DBW
    Ok so that one is still connected to the N249 Valve? Maybe I am misunderstanding.
    And here is a diagram I found of how to bypass it:
    From the looks of the diagram you would want to plug the hard line and run a vac line to both of those ports while leaving the side port opened up (or plugged also I guess).
    EDIT:
    Here is what it should look like when all done. This person removed the N249 ad N112 valves:
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Hmm, it doesnt look like I did it in the diagram. It makes sense once you think about it (unless I am completely wrong). From the description from others, it seems like all you do is make the DV go straight to the intake manifold.
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Thats how I did it.
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Re: Attn: All DBW
    DV straight to the front of manifold. alot of people have done JUST that.and no problems.......no looping or anything. as long as you keep the n249 still plugged in the ecu will not give a CEL
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Basically what I did.
    I just used the end of the hose that came off of the intake manifold and plugged the spot where the DV used to be.,
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Re: Attn: All DBW
    notice any difference in driving? i haven't done this yet, just read the thread thoroughly......... everyone that did it says boost comes in quick, and some even say that got more boost...
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    Re: Attn: All DBW
    Edit: Sorry didn't see the post before mine.
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Yea I went out earlier and gave it some boost but didnt push it to 23lbs (what my MBC is set for).
    I dont wanna say its "more responsive" because that might be all in my head. But it seems like the sound of my T28 is a little different when i am giving it 1psi, almost like I can hear the turbo a little louder like a k03.
    Edit: Ill do a couple pulls later today to see if I notice anything.
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Re: Attn: All DBW
    i just did this mod in about 5 minutes flat.
    i have a 2001 1.8t with open air intake and Apr 1.0bar and always spike at 17-18 max.
    that said, after this mod i seriously hit the 17-18 mark in first and second, and 20psi in 3rd and 4th for the record i've never hit 20 psi in ANY gear on the APR software before. And it seems like the boost does come in quicker.(this is going on me hitting full boost in 1st and 2nd which never happened).
    i was also hoping this would STOP my DV flutter, it seemed like it helped but did'nt stop it. any ideas? reverse DV? i think it's on there normal right now don't remember if i ever reversed it.
    Sep 01 2005
    Re: Attn: All DBW
    FYI i used this diagram exactly......very easy DV line straight to front of IM, then loop the n249 with the line that WAS going to the IM.
    i had a boost gauge so i put that in-line with the line from DV to IM
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Re: Attn: All DBW
    So after reading all the threads on this, I decided go out and do it. Took all of about 5 mins to do. I went out and did a few pulls, and I noticed a slight increase in throttle response. And it does feel like the turbo spools a tad quicker. But I notice that boost dies off earlier in the higher rpm's. So I will run this setup tonight, and part of tomorrow, and If I don't like it, I will prolly just throw it back to the stock setup.
    As for my car, I'm APR state 1, APR R1 DV, intake, FMIC, and exhaust.
    Saint Cloud, Fl
    Re: Attn: All DBW
    This mod is really those people who are running BT
    instagram ------------> low_enforcement
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    Yea it helped my flutter, but didnt make it go away. Did you loop the original IM hose back onto where the DV was connected tothe N249?
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Re: Attn: All DBW
    that's exactly what i did.
    Quote Originally Posted by 7speed View Post
    i am not BT and i would recommend it to ANY DBW. it's a free increase in performance, throttle response, boost onset, and raises your current boost settings. (still safe, because GIAC software hits 20+psi)
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    Re: Attn: All DBW
    hey everyone... im a noob when it comes to audis but this looks like a safe adn easy mod that i can do in my time off...
    ANYONE WANT TO TAKE Good Pictures an write up somethign for the DIY section?? i would like to do this but all of those diagrams with the red and blue dont help me too much idk i jsut havent been under the hood enough on this car to know all the terms and stuff...
    that would be really awesome and helpful to new audi owners like myself... thanks a lot
    Oct 22 2006
    Re: Attn: All DBW
    Quote Originally Posted by flynnr View Post
    I second DIY guide, someone should make one
    Jun 04 2007
    Austin/DFW, TX
    Re: Attn: All DBW
    It would be impossible to takepictures
    My 5-Speed Swap DIY
    - B6 USP
    Feb 27 2005
    North Wales, PA
    Re: Attn: All DBW
    don't need pictures. just open up the hood and go to work. there are 3 10mm bolts holding on the plate that the n249 mounts to. thats really all you need to know.
    Apr 10 2007
    Eastern PA
    Re: Attn: All DBW
    I agree with poopie, really no need for a DIY but if you do want one... here is a complete DIY of a vacuum cleanup with N249 and SAI bypass covered also (with photos):
    http://www.audizine.com/forum/showthread.php?t=235106
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Attn: All DBW
    I did this, look for my thread ill be posting pics tomorrow.
    -18 718 GTS
    Sep 01 2005
    Re: Attn: All DBW
    there you go i made a DIY.
    no but seriously if you can't do it from that diagram, then don't attempt it. It's as easy as it looks,took me 5 minutes FLAT. all your doing is re-routing 2 vacuum lines........
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: Attn: All DBW
    I did this mod last night in less than 5 minutes with nothing but long needle nose pliers and a phillips screw driver for the cover and the coolant expansion reservoir. Instead of looping the hose, i removed it completely and capped both ends instead. not too much of a performance difference but i am not chipped or bt. i did, however, notice 4th gear boost is even faster when going WOT at 3k (near instant), and 5th gear spikes to 13 instead of the previous 12. I'm not sure but it seemed like the DV seemed quieter when venting but it was also pouring rain. This does not seem to be too much of a performance mod and a placebo effect may be causing perceived gains.
    The following is just speculation as I'm just thinking out loud.
    I believe the reason the n249 was factory equipment is to extend the life of the stock diaphragm style DV as the solenoid will only open when it sees vacuum thus preventing possibly damaging boost pressure from pushing on the other side of the valve, which may cause it to tear. bypassing the n249 is now allowing boost pressure to access the DV and the observed gains may be due to better sealing of the DV by having the pressure to hold it tight in place.... again speculation. This may be detrimental in the long-run as the constant switching from boost to vacuum may over-exercise/wear away at the DV causing it to tear. I'm not sure if this would have as much of an effect on the piston style or updated 710n's but it is something to think about.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 10 2007
    Eastern PA
    Re: Attn: All DBW
    Quote Originally Posted by B5A4Kevin View Post
    I just did this mod tonight too. I figured while I was in there re-circing my BOV I would rip it out to simplify my vacuum lines a little bit more.
    As for the eventual ripping of the diaphragm in the diverter valve... that would suck for people that run one of them. Glad I have a BOV without a diaphragm in it.
    Sep 01 2005
    Re: Attn: All DBW
    i did notice my dv is a little louder when recirculating........
