Results 1 to 7 of 7
    May 13 2008
    '03 A6 4.2,,93 90q, '87 4kq, 03 Allroad
    Las Vegas
    Tire size for 4.2 with 19's....
    I picked up a set of BBS CH's 19 x 8.5, and H&R springs/ Bilsteins for my 03 A6 4.2.
    But I dont know what tire size to get.I saw that one website lists 255/35 and the other is 255/ 30,and I saw a guy running 265/30's. I would rather have the 35 series just to have a little more sidewall, but I dont think I can return the tires once I mount them.
    Any help much appreciated, and when its all done I will post some before and after pics.
    Active Member Four Rings kingofnyc's Avatar
    Jul 02 2007
    Queens, NY
    Re: Tire size for 4.2 with 19's....
    it depends on the offset. i run 275/30/19 and no problems. for daily driving i would go with 265/35/19.
    Maybe some more people have more info.
    May 13 2008
    Las Vegas
    Okay, thanks. I would be using the car for daily driving. The CH's are 19x 8.5 with a 35 offset, same as stock, if that helps
    Veteran Member Three Rings dtoys4.2's Avatar
    Oct 01 2007
    Imola%20RS4%20bagged/500whp%20300zxTT/Gated%20V10%20R8
    queens NYC
    im running 19x8.5 also and my tires are 255/35/19 and i run it everyday
    Registered Member Two Rings banditoamigo's Avatar
    Nov 02 2004
    2002 allroad MT6
    Minneapolis
    If you want to keep the stock size, just enter the old size and the new size into this:
    http://www.miata.net/garage/tirecalc.html
    Will also tell you how fast/slow any new setup will make your speedo.
    2002 allroad MT6
    Black/Tan, 3rd row seat
    Stage 3 - EPL tuned
    Sep 20 2006
    Burnaby, BC, Canada
    i've got 265/30 on the back of mine, but the rim is 9.5 wide... i wanna get something wider tho... i only have 235 on the front, but i think the widest for 8.5 rim is 255
    Feb 12 2007
    2001 Audi A6 4.2 (sold), 2010 Q5 3.2 (sold), 2008 Lexus IS250 AWD, 2011 Lexus RX350 AWD
    Unknown, AK
    255/30/19 is the recommended tire size if your stock wheel is 255/40/17.
    This is to keep the same rolling diameter as the stock setup.
    +/- 3% variation is the max suggested, but seeing as how these other guys are able to run hugely wide tires without issue, guess it's only a guideline.
