Results 1 to 9 of 9
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Arrow ticking at WOT after 3500k?
    Ok well im just curious to what could be the problem or if its normal. My friend also notices it and says "hey i think your car ticks"...
    I does it kinda loud and its usually only after 3500k rpm's. I would like to try and eliminate the sound. It seems like the faster the engine speed the faster the tick. (mostly hear it when the windows are down, i dont think you can hear it if the windows are up or the music turned up loud enough) Anyone have an idea?
    121k miles
    stock 12v v6
    manual
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: ticking at WOT after 3500k?
    heatshield hitting?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Nah no heat shield hitting man, I have the same thing. I think it might be the valves I have had it ever sence i had my engine repaired after my head gasket blew. Not sure what it is man if you find out let me know too.
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by biketsai View Post
    heatshield hitting?
    i mean it could be a heat shield thats a good guess idk. But damn that would suck if it was valves. WTF does that mean i need a valve job?
    Apr 22 2007
    Riverbank, Ca
    I had that when my turbo and exhaust manifold had a crack in it. It could be something like that...
    However Im just throwing an idea out there.
    May 18 2008
    SOOOOOO Cal
    you know what i think it could be that too maybe we have an exhaust leak.get some heavy duty jack stands and go under the car try to hear for any leaks, i'm doing the same thing this weekend.
    Apr 22 2007
    Riverbank, Ca
    Best way is to plug the exhaust/cover it, and listen for leaks when its running. This forces the air through the leaks.
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    are you sure its not pinging from running low octane gas?
    im not sure waht the ticking noise ur hearing sounds like but its aguess..
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by Beemer832 View Post
    im not an ignorant idiot that doesnt spend the extra $2 per tank for premium. Premium FTW.
