Results 1 to 37 of 37
Thread: Stock exhaust
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Stock exhaust
    Hi. I am a new S4 owner and am looking to chip my car. I want that extra power but dont want the noise.
    My question is, how big is the stock exhaust pipe diameter?
    You see i am thinking of a chip plus piggies on a stock exhaust. I just dont know if it will be louder or if the turbo will still spool faster or the same being that it still has to squeeze through stock piping. if the piping is 2.25-2.5 that doesnt seem that bad.
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    I edited my thread because my second question reguarded k04's with a chipped ecu on stage 1 tuning can be answered in the other thread.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Stock exhaust
    stock pipes are 2 1/4 inches. I did my own piggies and have stock exhaust on my car. barely made a difference in sound. Still very quiet. I kind of wish it would have a little more of a growl.
    I made a nice DIY for doing piggies. search for the ultimate diy for Piggies
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jun 24 2008
    Re: Stock exhaust
    Quote Originally Posted by Ianxcom View Post
    You can do piggies on the stock exhaust. It'll still flow a hell of a lot better than not doing them. Have you seen pictures of what the pre-cats look like? http://www.audiworld.com/tech/eng75.shtml
    I'm sure you can imagine how much of a restriction all that material is. Perhaps a bigger benefit of the piggies than just the easier and faster exhaust flow, is the fact that the massive heat generated from the turbos (which are placed literally RIGHT before that mesh-like pre-cat material) can escape way faster.
    With the stock downpipes, the pre-cats create a "traffic jam" of heat in the pipe. The turbo then has to force out the heat it generates on its own AS WELL AS the heat that's starting to collect in the "low flow zone" before the pre-cat. This all leads to potentially shorter turbo life, as they consistently get hotter than they would without the ridiculously restrictive pre-cat.
    Second question: If my k03's do crap out the k04 kit is quite expensive and runs higher boost. What is the performance like if i kept my chip programmed for stage 1 but with k04s. That way it will be only about 16lbs of boost but with more reliable turbos.
    No, it makes perfect sense. There are people out there that do run their Stage I K03 chip on K04s, and they don't seem to have too many issues. The only thing is that they are, after all, different turbos, so the Stage I programs aren't going to be as fully dialed in as a proper K04 file would be. But, it has been done. You know, you don't HAVE to get a K04 "kit." You can just get K04 turbos + inlets/hardware (from places like VAST, Avalon, ECS, JHM, etc.) and bolt them on. That's what people call Stage 3-. Any of the tuners that burn their own chips will be able to make you a Stage 3- file that is adapted to K04s without fueling components, so the chip won't demand crazy high boost. You won't need any of the additional "expensive" fueling components, you can get those later.
    Regarding the performance of a K04 car with a Stage I chip, it'll be pretty much identical to what you're used to with K03s. If you use the same chip, with the same amount of PSI, then you won't be seeing any power gains with the K04s. They will be MUCH more reliable, though, if you run them that conservatively.
    Hope that helped a bit.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    you could just get a scorpion exhaust or have a custom exhaust made for you with like 3 mufflers on it but have it 3"
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Thanks for the quick replies. The reason i would go k04 on stage 1 chip is i heard the turbos are more reliable (unless i can get rebuilt k03's or some other ballbearing turbo for cheap) and i dont want to take any chances on the stock rods with 20+ boost. Im just trying to prevent heartache in the future while getting more power.
    I suppose i could get a 3" exhaust with 3 mufflers but that seems like it may cost quite a bit.
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    oh and btw, smog checks are a big concern here in socal so that is also affecting my decision.
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    custom exhaust is way cheaper than ASP, AWE, APR, etc.. just get some magnaflows
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Do you mean 3 cats or 3 mufflers. Ive never heard of 3 mufflers before. Would that be more restrictive than the stock 2.25?
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    3 straight through mufflers. not cats. ive never heard of 3 mufflers either, but shit it might be pretty quiet. if theyre striaght through, they wont inhibit flow, but would still provide adequate sound dampening.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Stock exhaust
    Piggie Pipes and Exhuast along with anything turbo related won't matter in Socal. I have Full Stage 3 w/ Piggies and I pass no problem.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Quote Originally Posted by Rated S View Post
    Well that's good to hear.
    So another question. How do the s4 stock internals hold up to 16lbs of boost from a chip.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Stock exhaust
    Internals can hold like something up to 500whp iirc.
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    yeah man.. stock internals are great. our motors are made to take boost, no worries unless you're going to be running a high boost big turbo setup
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Wow. I had no idea. Thats impressive.
    What is the amount of hp/boost stock fueling can handle?
    I ask because i only really want to run 15-18 lbs of boost. and get around 320-340fwhp and 360-370 tq.
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    sorry to say but you'll never see 320-340 whp on 15-18lbs w/ k03s...
    stock fueling can handle like what.. 350whp, but you'll need bigger turbos (ie k04s, rs6, etc etc)
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    nooo. i meant fwhp. whp measurements are too crazy for me. =P
    So i take it i can just bolt up k04s and get it custom chipped for 20lbs and be ok on stock fuel then?
    And by upgraded fuel is that just bigger injectors and stronger fuel pump or is there more to it?
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: Stock exhaust
    Assuming you mean "flywheel horsepower", then you should hit those numbers (320hp/360tq+) with just a GIAC chip, possibly adding a catback and/or downpipes to seal the deal - stage 2(+)!
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Re: Stock exhaust
    haha. sorry, not to be a dick but the title of your thread should've been: "Stock exhaust, and everything else about these cars..."
    seriously though, you obviously need to do a little more homework. check out this FAQ sticky atleast once and I bet a lot of your questions will be answered: http://www.audizine.com/forum/showthread.php?t=128295
    ...the search feature will also help you with anything not answered in the FAQ sticky.
    GL and welcome aboard!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Thanks and i dont take in personal. I did look at the FAQ and did learn alot. I did a bit of HW and was going to talk about everything but i noticed another recent thread which i decided i would take the other question to so i edited my thread. Someone addressed my question so i guess thats how it got started.
    Mar 08 2007
    Mr. Worl-Wye
    Re: Stock exhaust
    no prob. I know I spent my first couple months on AZ, AW, and AF just lurking around and reading FAQ's and people's posts... that helped a bunch.
    Not sure if you finally got answers to your last questions, but usually people get what is called "fueling" or "custom tune" when getting ko4's (or other turbo larger than stock). You can run ko4's w/o this "fueling" (as many people do b/c it's expensive), and just run on an OTS chip but you won't get the full potential of the xtra flow/boost provided by the larger turbo; IIRC you might even have to get your chip "tweaked" too. This is called "Stage -3", instead of the regular "Stage 3".
    With these cars you'll also find many people using WHP or AWHP more often than BHP or crank-HP... You can search on typical drive-train loss percentages to make your own conversion, but I think for our cars it's about 22-23% (+/- 1-2% depending on who you ask).
    hope that helps.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Yes that helped a lot thank you. I have been doing alot of thinking and i think i will just go the GIAC (still need to do chip research but i hear this is most 'aggressive') and piggies. Other upgrades will be pending stock failure.
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    Re: Stock exhaust
    Quote Originally Posted by gointoscott View Post
    cut out the resonator. i did this and it sounds great at wot and stock at everything else and with the piggies you can hear the turbos through the tailpipe at idle ;)
    Registered Member Two Rings
    Mar 22 2008
    Terre Haute, IN.
    Re: Stock exhaust
    Quote Originally Posted by Jung View Post
    My Thermal R&D Exhaust for my 3.0 had 3 straight through mufflers per pipe (6 in total). It was close to stock quiet, 3" pipe with 3 straight through mufflers would be an awesome power boost to a turbo car while retaining nearly stock sound.
    The turbo acts as a pretty good muffler also.
    Midwest America Euro Technik
    '02 A4 3.0 Quattro: Thermal cat-back | Southbend Rally Clutch | Polished MAE Monoblock 19x8.5 and 19x9.5 wheels | H&R Springs | Bilstein Shocks.
    '87 BMW 325is: T3/TO4E at 15psi | 2.7 Stroker in the works.
    Jul 07 2007
    Tempe, AZ
    Re: Stock exhaust
    pretty good muffler if you're deaf.
    ever heard an s4 without an exhaust? not exactly quiet
    Jun 24 2008
    Re: Stock exhaust
    I'm not sure you understand what he meant. He was just pointing out that the turbo acts as a sound muffler in general, which is true. He wasn't telling the OP to run open downpipes because it would miraculously be "quiet."
    He was just stating that a turbo car with exhaust will always be quieter than an N/A car with that same exhaust, because of the muffling effects of a turbocharger.
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    I forgot about this thread I made.
    I have a friend who put an ASP 3" DP on his stage 1 car with stock exhaust. I now have an APR chip and was thinking of getting piggies because mated with a stock exhaust system i would think the gains are minimal if any when comparing the two. Both relieve the backpressure directly after the turbo and end up going out the same diameter in the end.
    Thoughts?
    Aug 06 2008
    Canadia
    Re: Stock exhaust
    not really loud either. Some engines you can damage your hearing if you rev them up without an exhaust. S4 won't do that. (i'm refering to a S4 engine with the downpipes in place and the cat-back removed)
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    Re: Stock exhaust
    I have piggies with stock exhaust. Still quiet as hell almost like stock. But you will definitely notice a difference in performance. Especially how quick the turbos start spooling. Torque comes in way faster. I'm probably gonna get a SSAC catback mated with my piggies for a little more performance and sound. You should find SSAC catbacks for under $200. Good luck.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Thats good to hear cuz i dont really want any noise at all.
    Mar 01 2008
    Toronto, ON, Canada
    Re: Stock exhaust
    "I don't want any attention."
    Sorry, had to (The Jackal).
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    Re: Stock exhaust
    yeah just to add a bit more knowledge to you, stage 3 cars run 20+psi easy (ie WITH fueling) and the reason everyone does all the upgrades at one time is due to the fact that it costs around 500 bucks just to get the motor pulled, so while you have it out why not do the intercoolers, waterpump, timing belt, clutch and turbos.
    I really dont understand your reason for not wanting a louder exhaust lol, I HAD cat back on my car when i first bought it and you could hardly even tell it had it.
    PS on AWE's site they say 460fw hp for their stage 3 kit
    '00 Nogaro Blue S4
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Re: Stock exhaust
    save a LOT of money and buy a tesla roadster =)
    Lurker
    Nov 22 2008
    01.5 S4
    Michigan
    Re: Stock exhaust
    gut the down pipes take out the middle resantor keep stock muffler or change it sounds perfect not loud at all thats what i did i got a wole exhuast system but didnt put it in yet
    Jul 30 2008
    Socal/Denver
    Re: Stock exhaust
    Quote Originally Posted by NogaroWonda00 View Post
    I had a honda with a loud ass exhaust for years. Just done with it. I chose this car for luxury and speed. Plus Im getting older and dont want to draw attension to myself
    Quote Originally Posted by lucajS4
    never thought about this. Will consider it only if it makes a noticable difference. Since exhaust only adds like 5-10hp anyways i didnt wanna mess with it.
    Jun 13 2008
    Rocky Mountains
    Re: Stock exhaust
    okay dont get me wrong but a s4 will never sound like a honda. think of it like this, noisy fart canned honda isnt liked much, but a clean exhaust on a s4 makes people cum in their pants!
    my car is pretty loud lol but i have had more people than i can count tell me the shit sounds sweet, doesnt mean its not luxurious, i guess my point is, the exhaust is a big part of the picture when your talking about power, if its not big your turbos dont spool nearly as fast, and if you do plan on throwing k04s in there its making them not work as good as it could be, but its your car your choice.
    '00 Nogaro Blue S4
    Jun 13 2008
    Rocky Mountains
    Re: Stock exhaust
    5-10hp, man dp's on a stage 3 have a 50whp gain!
    '00 Nogaro Blue S4
