Results 1 to 15 of 15
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Steering Whell Vibration!!
    hey guys,
    so this has been happening for a while but it just started to annoy me. When i come to a complete stop and make a turn or try to do a you turn at low speeds the steering wheel vibrates. I got the steering pumped looked at and its fine and i cant seem to find anything on this subject except wheel rubbing and its not that either.
    any suggestions?
    Established Member Two Rings dpoor3ch's Avatar
    Jul 10 2008
    B6 UltraSport, BMW X5 Sport
    Charlotte, NC
    Re: Steering Whell Vibration!!
    Outer CV joints (not inner).
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    check your tires?
    Jul 10 2008
    Charlotte, NC
    Inner CV, not outer...my bad. I am having a "clicking" noise and it's the outer.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    what do you mean the cv boot? i just got the right front axel replaced cause it was leaking grease, because the cv boot tore.
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    Check your tierods as well.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    bump. another member just pmed me and i believe i still have this problem even though all front control arms and tie rod ends were all replaced. I also replaced my cv boot on my front right side.
    im gonna double check to see if its still there!
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    does it only happen when braking? check you rotors. they might be warped.
    EDIT: also check to make sure that none of your caliper pistons are stuck out.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    no only when im at a standstill. if i cut the wheel all the way to make a u-turn it will vibrate.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    sounds like ABS kicking on???
    Established Member Two Rings G.O.A.T.'s Avatar
    Jun 22 2007
    2001 S4 STG2+
    Ontario,CA
    Quote Originally Posted by dpoor3ch View Post
    x2
    Liberating Horspower...one mod at a time
    http://www.straferight.com/photopost...-jiggle-02.gif
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    you think inner cv? how would i go about checking this?
    Established Member Two Rings Xenon01's Avatar
    Nov 30 2008
    Georgia
    I have the same exact problem..when i do a u-turn or turn sharp left or right i get crazy vibrations...both outer cv boots were torn so i replaced them but it seems to be getting worse..maybe inner cv boots?..Could the whole axle mess up if it ran without all that grease in the boot? im not sure how long it ran w/o all of the grease but im guessing it was a couple thousand miles
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    its not that bad as it used to be for me but the vibration is still there.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    bump!
