Results 1 to 17 of 17
    Established Member Two Rings caall99's Avatar
    Oct 02 2007
    Boston Area
    My S4 has a rough idle and DIESELS on shut-off!!!
    My S4 is having a hard time shutting off exactly when i want it to. It seems to diesel for a second or two longer and doesn't sound to healthy. car has 116,000 miles on it. It also has a randomly occuring stumble during idle that shakes the car. it's somewhat subtle, but can also be heard through my aftermarket exhaust.
    would a carbon deposit problem cause such symptoms in an S4?
    i am leaning towards steam cleaning the inside of my motor with some water, and using the front vacuum port that connects to the two DVs as the injection point. any input in regards to other maintenance i should be doing? spark plugs, MAF, DVs, TBB, etc... all that stuff has already been replaced.
    btw, car has no boost leaks and feels very strong with the pedal to the metal!
    2000 Audi S4 Black/Black
    XS-Power Turbo-Back Exhaust * APR Stage 2+ V5 93 Octane * 710Ns * AWE DTS * Short Shifter * Stern Power Ring, Rear diff. mounts, snub mount
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: My S4 has a rough idle and DIESELS on shut-off!!!
    Vag it and log for misfires...mine had some very subtle ones as well. Log blocks 015 and 016
    Oct 02 2007
    Boston Area
    cool thanks!
    was wondering how i could log miss fires. is it a counter system? (counts how many missfires within a time interval) do you think carbon deposits could be at fault? any ideas on the dieseling on shut-off?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    hmm what about leaking injectors. crimp off your return line for fuel and shut your car off.let it sit for a bit and disconnect your return line if fuel doesnt spray all over :) you have a leaking injector. or pull your fuel rail and key on and off a few time to prime the fuel rail with pressure and see if an injector is leaking
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by AudiTechS4 View Post
    I was thinking the same thing... that's about the only thing that will cause dieseling of a FI car.
    Join the OhioVW facebook group for gtg, show, and cruise instant updates!
    1998 VW Jetta GLX VR6 | 2001.5 Audi S4 6MT | 1984 VW Jetta GLi | 2004 VW Golf .:R32 | 2001 Audi TT 225 Coupe quattro
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah any car running on needs fuel. only a leaky injector or injectors can cause that
    Feb 09 2007
    00 S4
    MA
    I have a similar problem with my car, although is seems like yours is worse.
    I changed my spark plugs, and seamfoam the intake mani and fuel.
    no change is misfires/rough idle.
    I am going to change out all the coilpacks, and hopefully that will get rid of them.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Oct 02 2007
    Boston Area
    check this out.
    I did some vag logging of my car and it turns out that i sometimes get 1-2 missfires per minute in cylinders 2,3 and 6. again, nothing major but the subtle missfires are there. car does not rev 100% smoothly, there is some noticable choppiness in the lower RPM band.
    another vag com scan measuring "cylinder voltages" yielded some interesting results. i am guessing "cylinder voltages" are the voltages from the ignitor to the coil packs?? i feel i might be completely wrong in my assumption but then again this next bit might prove me right. It appears that cylinders 1-3 have a common voltage of .6V and cyls 4-6 have a voltage of .9V (on average). my two ignitors are different colors (one is yellow and one is black). could there be some sort of ignition imbalance across my motor? i just want your input on this and maybe some of you could do an "advanced measuring block" scan for cylinder voltage. Its in the list that pops up when you go to advanced measuring blocks under the Engine - Control Module.
    Picture showing voltages of all cylinders on a short drive through town. (sorry about shit quality, but cyls 4-6 are the highest three lines, cyls 1-3 the lower three)
    Oct 02 2007
    Boston Area
    another update... here are the missfires. my short logging trip started with the car cold and ended with it at normal operating temps. i never drove it hard. something is messed up here. plugs? injectors? ignitors? coil packs? what else could it be?
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    I'm interested to know as well.
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Oct 02 2007
    Boston Area
    True story... but no one is saying anything...
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    what measuring block are you measuring in vagcom? are you logging this during closed loop fueling (normal driving) or open loop (WOT)
    misfiring could be your plugs, could be bad gas, could be carbon deposits ... etc etc
    just start troubleshooting step by step
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Jan 12 2008
    Quote Originally Posted by DxC View Post
    Yeah, start at one spot and go from there.
    My suggestion before you buy anything. Start the coil pack swap. ie swap coil pack 1 and 6 and see if the misfire goes follows the coil or stays with that cylinder.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    i bet you have a major boost leak. My F-hose came partially un-done....and it idled exactly like you're talking about. Check your f-hose. Its at the front of the intake manifold, right behind the passenger side DV. It might be torn if you have a stock one still, and if you have a samco one like me, it just might have worked it's way loose.
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    I have the same problem and am tearing my engine apart on sunday. it is a blown head gasket for me anyways
    Oct 02 2007
    Boston Area
    logging 15-16, those logs were on boost and off boost, but nothing all out full throttle for the missfire logging anyways. car feels great on boost and high rpms. its below 2k that i get some weird inconsistencies. sometimes, once in a blue moon i'll get one massive missfire that essentially makes the whole car shutdown for a split second. like a huge stutter. Its not repeatable and happens randomly.
    i think i may have to do some part swapping. one ignitor, ie. ignition control module on the air box, is yellow or brown (can't remember off the top of my head) while the other is black.
    On a final note: the car has been maintained meticulously in the past, and driven normally. the previous owner did not beat on the car. i truly believe it's a part wearing out/breaking due to age and mileage (116,000) i replaced the plugs with regular copper ones 3000 miles ago and gapped them down. it might be time to check on them. with all my egt, o2, maf and boost leak issues, it may be that they are fouled by now.
    I fixed my most major boost leak, namely the TBB. i also replaced the MAF and put new 710n DVs in the car. i know a mechanic noticed that the f-hose had been replaced in the past. when i did a smoke test the only place it leaked from was the TBB, but then again the smoke may not have escape elsewhere because the tear in the TBB was so bad that it was quite obviously the point of least resistance for the smoke to escape from.
    you're scaring me man. i am losing coolant somehow. very very slowly though, like an inch in height in the coolant expansion tank since i have owned the car. i bought the car last october, so an inch per year? please don't tell me it's the headgasket. i am def going to pressure test each cylinder this weekend.
    Veteran Member Three Rings DoGGRoBBer's Avatar
    Dec 24 2006
    2000 S4, 2008 Touareg
    Upstate NY
    As to the coolant loss, you have 2 other possible issues. Mild ones so don't get woorried. The is a secondary water pump that runs coolant thru your engine after shut off. It located under your intake manifold, and is most likely leaking a small amount. Look for a pinkish crust forming behind the F-hoes area under the intake. The other one may be your leaking coolant at the turbos, fore they"re both water/oil cooled. The "crush washer" gasget on the underside of the turbo may need replacing.
    -Mike
    2000 S4 SSP Tuned Stage III ,K04's,SSAC Downpies, Scorpion Exhaust, RS4 Clutch, APR Bi-Pipes, APR Snub mount, VAST MBC & TCD running 20-22 Psi., APR SMIC, Bosch 710N DV's
    2008 VW Touareg
