    Jun 13 2008
    Bay Area
    oil leak- under warranty?
    hey guys,
    i have been noticing an oil leak on our B6 1.8T. I have jacked the car up and do not notice where the leak is coming from. We got an oil change about 2 months ago, but the leak only started this week. I checked the oil filter, drain plug and the leak is not coming from there. I have no idea where it is coming from. If I take it to the dealer would it be covered under the warranty? We bought the car used in August but from a VW dealer, it should still be under warranty if the car only has 31000 miles correct? It is a '05 B6 1.8T quattro. Any help is GREATLY appreciated guys.
    Thanks in advance.
    raphael
    Feb 09 2008
    Re: oil leak- under warranty?
    The 'in-service' date also comes into play. Over 4 years and your on your own.
    Given your in an '05 you should be safe.
    Most likely you have a valve cover gasket issue, also maybe a cam-tensioner seal out. I had both on my '04.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Could be as simple as the oil plug being a little under-torqued.
    Poke around, they are usually pretty easy to trace. If you still have a warranty, Im sure that it will be covered unless its something related to the oil change like a loose plug or filter.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Jun 13 2008
    Bay Area
    the oil plug and oil filter are on tight... i dont see any type of leaks from those two locations...
    Registered Member Four Rings
    May 11 2007
    RS6 Avant/996 GT2/'08 335i
    Southern California
    Definitely under warranty. Take it in and they'll fix you right up.
