Results 1 to 15 of 15
    Established Member Two Rings A4Gasm's Avatar
    Jan 24 2008
    98 Audi A4, 06 Suzuki GSXR600
    Boston Massachusetts
    Lots of repairs done. Now I have a question about boost.
    I posted a thread a couple months back when my car was hurtin' bad. Turbo was dying, no ABS, up near the "CHANGE THE F****G TIMING BELT" mileage, winshield washer pump broke, constant misfiring etc, and generally just stock slow
    Well here's everything I had done/price for anyone who's currious
    That puts it around $3700 in parts alone. Can anyone guess what labor costed? haha Was it all worth it. Yes and No. Yes because the car runs better than ever and I'll definately get another (at 76k) 40K out of it with prob just the occasional control arm, coil pack, vaccum leak etc. No, because I'm ADDICTING TO MODDING THE FRIGGIN THING That being said, can anyone suggest some good shock and spring kits? After that, I think I'm all set aside from the occasional cheap exterior mods ie. some valeo e-codes, smoked tails, better brakes and rotors
    So here's my boost question. Before the flash I was doing 5psi. After I got the ECU flashed with GIAC PUMP, I hopped on the highway, peaked at 25 and stayed between 20 and 23 on full throttle through the first couple of gears. Is that too much on an 800 dollar hybrid turbo. A buddy suggested a boost controller and a turbo timer or else I'm diggin the thing an early grave.
    Feedback? Thanks in advance.
    98 A4 1.8TQtip
    Gpop K04 Hybrid / GIAC pump /3.0" magnaflow at the downpipe / Baily DV / AWE Vent Boost Gauge / 17" Gloss Black S4 AVUS / K&N in stock box / Smoked Side Markers / Debadged / 20% Tint / Kamie Grill / Facelift Tails with Foglight Mod / Blitz Dual Turbo Timer
    Buy my cd player and subs please http://www.audizine.com/classifieds/...ct=2353&cat=44
    Registered Member Four Rings
    May 11 2007
    RS6 Avant/996 GT2/'08 335i
    Southern California
    Re: Lots of repairs done. Now I have a question about boost.
    I'm sure someone from GIAC will chime in with an answer for you
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    Quote Originally Posted by A4Gasm View Post
    I am assuming that by "pump flash" you mean that you simply got a basic K03 software flash. If so, you are definitely overboosting and this is normal behavior when running software that is mismatched with the turbo.
    I don't see a 5 bar or fuel injectors on that list either, if you continue running it as is, the EGTs will likely eat the turbo before the overboost does.
    I might recommend contacting your GIAC dealer to make sure that you have the correct software installed as well as, the hardware to accompany it.
    Jan 24 2008
    Well, I know very little about this stuff so and confided in this guys wisdom. I mentioned how most K04 kits came with 5bar FPRs and he told me I didn't require one. In regards to the flash, he said it was a stage one flash and I could choose from valet, pump, or race.
    Is it possible that I damaged the turbo already? ( what are EGT's)
    How much will a 5bar fpr and some injectors run me?
    PS. According to the rules and guidelines, tech talk is not recommended for the beginner to the Audi or B5 A4 scene- sorry posting here.
    98 A4 1.8TQtip
    Dec 05 2007
    That was referring to individuals whom respond to inquiries. You are the one posting an issue you are having, so you are following the guilines correct.
    But you would need to get the components for the k04 set up. That would include an FMIC, custom exhaust (not needed, but recommended to free those ponies), FPR (or an AFPR), and injectors. As stated above, call your closest GIAC dealer and have a talk with them. They will tell you what injectors you will need and FPR (as stated before, it is better to get an AFPR w/gauge). You could source those out for fairly cheap price after you find out what you need. Then you would need GIAC to grant you the correct tuning.
    Jan 24 2008
    An FMIC is required even though I won't be running that "aggressive" PC-16 file?
    98 A4 1.8TQtip
    Dec 05 2007
    It is suggested to even run an fmic on a stock k03 w/flashed ECU. I myself have not gotten an fmic yet, and winter is aproaching so not too big of a concern for me at the moment.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    for that much boost i'd at least be running tt225 injectors. imo a turbo timer isn't a necessity. just stay out of high boost (above 3-5psi. no boost is better) until the car is warm and let it idle a little after you get done driving it hard. talk with giac but on a k04 i wouldnt go higher than 20 psi anyway because of efficiency of the turbo.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jan 24 2008
    ********** to me
    show details Oct 10 (2 days ago) Reply
    Once again you are running a K03/K04 hybrid turbo. It is not capable of sustaing the boost levels that K04 software will demand. We flashed your vehicle with the correct K03 software for your application. If you are worried about your indicated 23psi, then run a MBC in parallel. EGT= exhaust gas temperature. Any more concerns call the shop.
    - Hide quoted text -
    On Fri, Oct 10, 2008 at 2:09 PM, ********** <*********> wrote:
    Looking for feedback, please.
    On Thu, Oct 9, 2008 at 10:20 AM, *********** <********@*******.com> wrote:
    I agree, this whole Hybrid thing is confusing. The manufacturer indicated it was capable of producing 210hp which leads me to believe that it leans more towards being a K04 (which are capable of 230). I can't get a definitive suggestion from them in regards to what program would work best with their turbo. I guess I'll have to go the route of a manual boost controller as you suggested. But how do I deal with all that talk on the forum about new injectors and a 5bar FPR. Someone mentioned the "EGT"s killing the turbo before overboost. What is meant by "EGT"s?
    On Thu, Oct 9, 2008 at 9:12 AM, ******** <***************@****.com> wrote:
    There seems to be some miscommunication. From what you said you have a K03/K04 hybrid, not a K04 hybrid, running K04 software on this setup will almost certainly destroy your turbo as well. Unfortunately, to my knowledge there is no software specically designed for this turbo. Also, you need to be sure your wastegate acuator is set correctly. After that you could (hate to say it) run a manual boost controller in parellel, only parrell to limit the peak boost. Please give the shop a call with any qustions.
    On Wed, Oct 8, 2008 at 4:50 PM, ******** <**********> wrote:
    Greetings,
    My name is *********** and I was in last week with a 98 A4 1.8T Quattro Tip. I paid $375 to have my car flashed.
    I've been informed that I may have a software mismatch which is causing me to overboost. Per my conversation with *****(sorry, not sure which one) 15psi (give or take ) was estimated after the car got flashed. When I left the shop, I was pushing 20-25 - which ,as the manufacturer of my turbo has indicated, will ensure early death of my new turbo. Here is the link from audizine where I received the feedback.
    http://www.audizine.com/forum/showthread.php?t=238450
    People are mentioning a 5bar FPR and new injectors- both are included in most K04 kits I've been seeing online. If this is true, I'm surprised that this was something which was left undisclosed last week.
    This is the turbo
    http://www.gpopshop.com/kkkturbos.html
    Please let me know how you feel we can resolve the situation. Are there any other GIAC dealers in MA because that drive to Greenland costed about $20 in gas
    Regards,
    So according to the guy at east coast european, my hybrid can only handle a K03 file... kind of diaspointing since it's been said to produce 210hp... not sure if that's achievable with my current software. Unfortunately, noone has any info as to what software would perfectly compliment my turbo - oh well.
    So it looks like im in the market for a boost controller
    Quote Originally Posted by B5A4Kevin View Post
    I am clueless about the injectors/FPR thing. Why do I need new injectors but not a FPR? Thanks in advance for pushing me in the right direction.
    98 A4 1.8TQtip
    Jan 24 2008
    When boosting around 15-20 psi, is it common for an unusual smell to come from the engine? I don't know how to describe it, all I know is when i hit the gas hard, and boost up to around 15 or so, I smell something.
    98 A4 1.8TQtip
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    Did you get your turbo from gpopshop? If so, beware: http://www.audizine.com/forum/showthread.php?t=226637
    The bottom line is that there is no off the shelf software for the turbo you bought... so you are going to have to put together a frankenkit from both the k03 and k04 parts bins
    Jan 24 2008
    Yes, I did....Oh that's just effing wonderful.
    98 A4 1.8TQtip
    Jan 24 2008
    Quote Originally Posted by MultiAudis View Post
    frankenkit?? is the $375 I spent on my file at eastcoasteuropean now useless?
    98 A4 1.8TQtip
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    Gpop states on there website that there turbos are compared to a k04-015. AWE has a kit for it. So if you copy there kit and fallow that. This may put you in a better situation. I can't confirm this. I'm in the same boat as A4Gasm.
    Jan 24 2008
    Quote Originally Posted by Ayefore View Post
    I had my eye on the AWE k04 kit for months with cash in hand. I gave up waiting for borgewarner to ship K04-15's (which I'm told will finally happen in December). My car needed lots of other work so something had to be done. I'm pissed that they compare it to a K04 seeing as I went to get it flashed and the shop told me it's basically a little better than a K03sport...
    98 A4 1.8TQtip
