    Registered Member One Ring I_Ghostrider_I's Avatar
    Apr 30 2008
    New York
    Looking For reliable Shop
    Does anyone know of a reliable shop in Connecticut Danbury area or close to it? I have a misfire on cylinder 1 and 6 I've changed my MAS sensor my Coolant temp sensor and its also saying my Air temp sensor is bad. I have the sensor and I bought a new bracket but the old one was just hanging and I don't know were the bracket blots on to. Not to mention I have a leak in my Power steering, it looks like to be a hose but it could be that cooler thing in the front of the car. any help would be appreciated.
    This is the Vag results
    Address 01 -------------------------------------------------------
    Controller: 4D0 907 551 AH
    Component: 2.8L V6/5V MOTR HS D01
    Coding: 06201
    Shop #: WSC 06313
    9 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16685 - Cylinder 1 Misfire Detected
    P0301 - 35-00 - -
    16690 - Cylinder 6 Misfire Detected
    P0306 - 35-00 - -
    P0300 - 35-10 - - - Intermittent
    P0301 - 35-10 - - - Intermittent
    P0306 - 35-10 - - - Intermittent
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    17834 - EVAP Purge Valve (N80): Open Circuit
    P1426 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 M
    Component: ABS/EDS 5.3 QUATTRO D31
    Coding: 0273004134
    Shop #: BB 24302
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor: Front Right (G45)
    30-00 - Open or Short to B+
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 D
    Component: A4 KLIMAVOLLAUTOMAT_D75
    Coding: 04162
    Shop #: WSC 06313
    4 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-10 - Open or Short to B+ - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    01206 - Signal for Duration of Ignition: OFF
    27-10 - Implausible Signal - Intermittent
    01582 - Signal for Coolant Temperature
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 930 L
    Component: B5-KOMBIINSTR. VDO D03
    Coding: 06262
    Shop #: WSC 00000
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 N
    Component: CV-Pump D05
    Coding: 16172
    Shop #: WSC 06313
    2 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06313
    No fault code found.
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186
    Component: Radio D01
    Coding: 00117
    Shop #: WSC 06313
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    Re: Looking For reliable Shop
    driversport in mahopac, i worked there over the summer. # is 18456212393
    they do GREAT work on audis/vw's/porsches..
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Registered Member Four Rings
    May 11 2007
    RS6 Avant/996 GT2/'08 335i
    Southern California
    Sounds like a coilpack failure for your misfires, which is an easy fix
    Apr 30 2008
    New York
    Thank you all for your input, today out of curiosity I swapped the old coil pack with the new one that I had installed and the problem went away. Seems like the new coil pack went bad. Gonna have to call and get it exchanged. But how bad is that? That new coil pack isn't even 3 months old....grrrr
    May 11 2007
    Southern California
    Quote Originally Posted by I_Ghostrider_I View Post
    Coilpacks are like ticking time bombs on these cars. Age almost has no bearing on their failure, it can happen to a 1 day old car, and sometimes they'll never fail. I've had my share of coilpack failures too... Its definitely not a bad idea to keep a spare or 2 in your trunk.
