Results 1 to 40 of 53
    Oct 03 2008
    the hood
    going from M3 to A4....what to look for
    Long story short I am leaving the BMW/DTM seen to buy an audi for many reasons. I seem to spend more time under my current M then driving it. Im looking at buying a B5 A4 1.8t AWD. I'm not looking for speed or HP as I had that in my M. I want something reliable and good in the snow. Why im going with an audi. I may do a chip/exhaust/suspension only. What I ask you guys since i am new to the scene is what year to buy? best year for mods/reliablity? common problems and issues to look for during purchase. i read over the B5 FAQ thread already so I have some knowledge there. i should be picking one up this weekend as i sold the M already. thanks for the help
    BMW 330IS: S50 95' M3 motor/98' M ZF trans/3.23 LSD/full suspension/race bushings/LTW wing/AE headlighs/M3 LTW moldings.....MUCH MUCH MORE!
    Oct 03 2008
    the hood
    she will be missed........
    Jun 01 2008
    Apopka, FL
    Re: going from M3 to A4....what to look for
    I have a 1999.5 and it's the "most mod friendly" I guess you could say, it has the facelift interior and headlights ( most easily identified by the 1 piece headlights) but still has the aeb motor with dbc and a strong bottom end. Throttle most important maintiance or the aeb 1.8t is timming belt and quality oil changes due to engine sludge, other biggies are control arms and clutch (for chiping) but not nearly as important as the previous two)
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Try to get a 2001.5, 99.5 is good but so is 2001, try to avoid the 2000 year tho. As the previous post stated, make sure the timing belt has been done, and so is the clutch,control arms and turbo otherwise be ready to pay a hefty repair bill, if you are going to put suspension on it, don't worry about getting the sport package.
    Anyways good luck and Welcome to the Audi scene.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Oct 03 2008
    the hood
    are these cars easy to work on? replacing timing belt....control arms? i did the motor/trans swap on the BMW so im good with a wrench. what us the typical milage for the timing belt replacement.
    sounds like a alot of major stuff on these cars! turbo/clutch/control arms. how are the bushings? thats BMW's biggest thing. bushing need to be replaced ALL THE TIME
    Feb 03 2007
    Parsippany
    Quote Originally Posted by dtm330ispwr View Post
    Yea, if u did swaps it should be easy for you, the timing belt should be replaced at 60k miles, the Audi book tells u to do so at 105k, but a lot of people have broken them at 80k and had valve damage and what not.
    These cars are reliable too, if u do preventative maintainence, they wont let you down, I didn't mean to scare you but basically what im trying to tell u is get a well maintained vehicle.(ask the owner for records) Try not to get a modded car, as u don't know has it been beat on or not?
    Prey
    Oct 03 2008
    the hood
    Quote Originally Posted by prey View Post
    cool thanks. i found some low milage ones for $10k with 60-70k and will likely take it to a dealer before purchase to do a check up since i dont know the cars too well. seems like all german cars a "preventative" maint cars. if there is oil in a honda/acura it wont let you down. i love german cars so im sticking to them.
    Oct 29 2005
    10speed
    San Francisco, CA
    your going to have to watch things like tie rods/control arms, boost leaks, and basically the timing belt. Timing belt should be done at 60k-70k
    Also, as soon as I got the car, I would seafoam it to get rid of any junk in the engine. These motors are prone to sludge if synthetic oil was not used from day 1, so a nice engine flush will help you in the long run
    Good luck
    - Clint
    Forum Moderator Four Rings docurley's Avatar
    UK London
    You wont need a clutch for just a remap the stock unit will be fine but it's recomended to upgrade the Diverter Valve if you do.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Jun 01 2008
    Apopka, FL
    umm.. easy to work on? Generaly, yes, like with anything it's a PITA the first time.. however the general design of the car is that the engine is as far forward as possible to increase interior room.. but this presents the problem since to do basicaly *anything* as far as maintiance or turbo work the front bumper, and radiator core support must be removed.. this has the advantage of making everything extremely easy to access but you must drain the coolant every time.. I used to replace it with fresh G12 but being $30 a gallon at the dealer.. now I just get a clean bucket and re-use it. The bumper is easy to remove, being held on by just 2 bolts, the core support is also fairly straight-forward..and that generaly follows everything about the car, lots of room, straight-forward and few hidden stuff, just there's lots of it so it's time consuming.
    another noteworthy thing is that the intake manifold is easily removed allowing access to all the cra* on the side of the block like the oil cooler and coolant pathways.
    bushings aern't really an issue, since they're all in the control arms and you just replace those every 80-100K.. if you up the HP, rear axel bushings and motor mounts ect.. should be upgraded but that's about it.
    if it were a low-mileage car or had a new replacement clutch I'd say yes, but since it's more likely it's going to be using an orginal clutch and have 90-100K.. he'll be needing to look into a replacement or soon after.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    X2, everything is pretty easy, but like all old cars, things seize up. The A4 is a very fun car and im sure the mod bug will bite you soon enough after you get one. Really, any year above 99.5 (facelift, one piece headlights) is good. But 99.5 has the strongest motor.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Quote Originally Posted by blmlozz View Post
    umm.. easy to work on? Generaly, yes, like with anything it's a PITA the first time.. however the general design of the car is that the engine is as far forward as possible to increase interior room.. another noteworthy thing is that the intake manifold is easily removed allowing access to all the cra* on the side of the block like the oil cooler and coolant pathways.
    Yea, and the foward engine placement means understeer is a bitch. I can't believe u would go from an M3 to an A4 dude. A4's are a ok car and don't excel or suck at much of anything, but I wouldn't buy one from a dealer. Private seller, one owner with full maintence is the way 2 go.
    Dec 14 2006
    Halifax, NS, Canada
    Honestly the e36 is a much easier and more reliable car then a b5. What are you keep having to do to yours?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    BMW/DTM seen
    LOL, that is all.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    I would say that they are very easy to work on, the engine compartment is laid out very simply and logically, and you can do a lot of stuff without taking the front end off, that just makes it easier but it's possible to do work without removing it.
    go 99.5, they rule, i have witnesses
    {99.5 Avant}
    Oct 03 2008
    the hood
    Quote Originally Posted by offroader1006 View Post
    LOL, that is all.
    i saw that. i edited that right away
    Oct 03 2008
    the hood
    Quote Originally Posted by Squarrl View Post
    everything! granted i dont keep up with maint that well because of a new condo. i have replaced the cooling system, all rear bushings and trailing arms. subframe cracked/welded M3 plates in, motor/trans/diff because of my own doing.....list goes on. some of it is my fault the way i drive it. i know they are great cars and i would like to buy into another, but my first experience wasnt the best. so im kinda scared.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    98's are the best, for seriol.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    Re: she will be missed........
    Why did you change your "M's" front bumper, mirror to reguar 3 series???
    Bad Ass I Beam rods are finally here. Join the Brute Revolution
    My Car is for sale, click here:http://www.audizine.com/classifieds/...?product=39888
    Oct 31 2004
    Michigan
    +1, I've had 4 E36 M3s and even more B5 A4/S4s and the M3s were more reliable and easier to work on. My gf loves Audis so I keep getting them for her plus for the money they are a great car as long as you know how to work on them. You can get a nice late model (99-01) for around 5k, and for way under that if you're willing to buy something that needs a little work.
    You did mention that you drove your 3-series hard hence all the work it needed, the same will apply to an Audi. If you drive it hard and beat on it, it will require more maintenance. To me it sounds like you need to test drive a few 98-99 M3s. A 325 with a S50 is not a M3, sorry. If you do want to get into an Audi please don't pay 10k for a B5 you can find a B6 for that price.
    Jun 25 2007
    Phoenix
    Quote Originally Posted by dan4g63 View Post
    +2 I'm a BMW tech and own a B5 A4. BMW's are so much easier/more logical to work on. I love the E30 and E36 layout. The only reason I think you might like the Audi better is for the snow which no one will argue. But the E36 is way more reliable in my opinion and will last longer than an a4 with the same amount ($$) of maintenance
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    I spy 3 series not m3 :P
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Nov 15 2007
    Audi A4
    Redding, California
    it says in his sig that he tossed an M3 motor into his 330....
    besides that....as long as you get a 1.8T with quattro and turbo you will be happy...everyone here has a B5 between 96-2001 and we all like our cars for different reasons....
    gl on your purchse....when you pick one up post pics!
    Oct 03 2008
    Orange County
    [/QUOTE]
    Ok lets start off with the basics, 3 series diffuser + 3 series mirror + 3 series front end + 3 series suspension + s50 m3 motor =/= M3. Second, bmw doesn't charge almost twice the price for the car for a different motor, the suspension is completely redone along with countless other things. Third, maybe if you had an m3, you could "push" it as hard as you do and not have problems. Also, DTM scene? WTF?!?! For an m3, the only thing people are actually using that has anything to do with DTM is exhaust TIPS. Lastly, your exhaust doesn't look like it fits right. [/rant] It would have been fine if you called your car a 325, or a 330 cause you put the s50 in there, but to keep labeling it as an m3 is just ignorant and kind of poser-ish. Scratch that not kind of. Anyways, good luck with your next car!
    Oct 03 2008
    the hood
    Quote Originally Posted by missionhcky09 View Post
    Ok lets start off with the basics, 3 series diffuser + 3 series mirror + 3 series front end + 3 series suspension + s50 m3 motor =/= M3. Second, bmw doesn't charge almost twice the price for the car for a different motor, the suspension is completely redone along with countless other things. Third, maybe if you had an m3, you could "push" it as hard as you do and not have problems. Also, DTM scene? WTF?!?! For an m3, the only thing people are actually using that has anything to do with DTM is exhaust TIPS. Lastly, your exhaust doesn't look like it fits right. [/rant] It would have been fine if you called your car a 325, or a 330 cause you put the s50 in there, but to keep labeling it as an m3 is just ignorant and kind of poser-ish. Scratch that not kind of. Anyways, good luck with your next car![/QUOTE]
    it says 330 in the sig. full M3 suspension/subframe/bushings, or powerflex bushings. it will keep with an M on the track and pull on one in the 1/4. buddy ran at 96mph (98' s52 with mods), i ran 103mph both ran a 15.0 (s50 with mods). both didnt have traction.....crappy day at the track. besides cometic and interior i am every bit an M besides the brakes. DTM scene yes.....as in DTMPOWER.net i wasnt talking about the ricer tips. i dont label it as an M. no M badge anywhere on the car. i had a 318 on there for a bit for sleeper. hopefuly all you audi guys are like this. i can play this game all night long. you got your M near by?
    Oct 03 2008
    Orange County
    haha funny thing, its actually about 20 feet from me... and by the way, no matter how hard you try, you can never make your 3 series feel like an m. you just said "i dont label it as an M." Exhibit A, thread title. Exhibit B, first post. And you were right with that 318 badge, closer to your car than an m3 is...
    EDIT:
    PS. It's a real one.
    Oct 03 2008
    the hood
    EDIT:
    20ft? you live in the hood? its far from a 318 and put your M against it or your B5
    Apr 01 2007
    Irvine
    EDIT:
    man, people like you are why i'm hesitant to go to any audi meets.
    Oct 03 2008
    Orange County
    haha o god... so you want to challenge your m3, that has nothing done to it? knowing you its probably a slush box auto... and sorry, my apologies 100 ft...
    Oct 03 2008
    Orange County
    sorry for the double post, but you completely over looked my half my post. mostly concerning why you called your 325 an m3? maybe you overlooked it...
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Quote Originally Posted by killa View Post
    im gonna have to agree with these guys, he blatantly calls his car an M3, that's like me slapping on an s4 front, side skirts and calling my a4 an s4. EVEN if i did a 2.7tt swap, it's still an a4 with and s4 motor.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Apr 01 2007
    Irvine
    to OP: don't worry, most audi owners are helpful people. don't let the remainder scare you away.
    1.8T's are very easy to work on, once you learn to get the car into the service position (front bumper, radiator, AC condenser off). as long as oil changes were done regularly, they should last a good while.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Get a Subaru. Seriously.
    ÖMGHI2Ü
    Photography
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    you guys are asses, he came here looking for help not Fn clowned on. F u guys.....
    ive been around here long enough to see this place evolve. and yea, get a b5 S4 or wrx.
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    i bought my a4 with 167k on the clock a few months back, but only because I knew it was serviced very meticulously in its life. its given me 3 months of service without absolutely 1 problem, never seen the check engine light come on yet.
    just make sure if you get a car in the 50-70 range, you talk them into a timing belt/water pump change also, or you could be out another 700-1500 for parts and labor on changing that a few miles after purchase.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Oct 03 2008
    the hood
    i can care less what they say. fact is i called the guy out and he has yet to step up. i have the car till wed and if he wants to bring his B5 out i will be more then happy to show what my car can do. he probably came from the vortex forums. i will let him rant. i never call my car an m3 on any of the BMW forums, reason i posted here is because 90% of you guys would have no clue what a 330is was if thats all i posted and i didnt want to explain what it was.
    thanks for the help from others. funny you say subaru because i have been looking at wrx's aswell. will update on what i get next week. stage 2 wrx for 10k a couple miles away. may take a look.
    Sep 23 2006
    Jersey
    Chill out dude, i saw that your car wasn't a M, it may have M suspension and motor but not registered as a M, but I was making a Joke as I knew what you were talking about.
    As for your questions, your car is most likely more fun to drive than an Audi, but Audi has quattro and that's what brought me there as well, AWD is .
    You can pick up an earlier A4 1.8t for cheap and do all of the basic keeping up for, even go with a larger turbo for more fun.
    Hope this helps and good luck
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    EDIT:
    toolbag
    Exhibit A: One Ring.
    He only talks that way because he hasn't been here long enough for someone to set him straight.
    I think your car is tits bro and I respect what you did to yours more so than if someone had just bought an M. my two cents.
    Oct 03 2008
    Orange County
    Called me out, one i don't even know where you live and two it was four in the morning...
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    EDIT:
    lol owned
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
