Results 1 to 16 of 16
    Established Member Two Rings cgmiller63's Avatar
    Jul 01 2008
    2006 Audi A4
    Southern California
    Differences Between Audi Transmissions
    What is the difference between Audi Tiptronic, Multitronic, Continuous Variable transmissions?
    Established Member Two Rings stephengraham's Avatar
    Aug 27 2008
    Fredericksburg, Virginia
    Re: Differences Between Audi Transmissions
    Jul 01 2008
    2006 Audi A4
    Southern California
    Thank you! My car has the Tiptronic and I hate the lag upon acceleration from a dead stop. It seems worse on hot days. My service advisor tells me this is normal for the Tiptronic. Are any of you experiencing this or is he blowing hot air up my a$$?
    Veteran Member Four Rings Monizzle's Avatar
    Dec 27 2005
    Mercedes S550, 2012 Audi A4 quattro
    i'm assuming you're turbo'd bro, and that's heat soak taking over causing lag.
    our turbo'd cars crave cold air.
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    Quote Originally Posted by cgmiller63 View Post
    if your A4 is a FrontTrak sedan, then you've got a CVT trans.
    I experienced more lag with CVT, compared to 6 spd tip, when I test drove both.
    the sales guy said it's typical with CVT, but I didn't care much since I was going to buy a quattro anyway.
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Jul 01 2008
    2006 Audi A4
    Southern California
    Quote Originally Posted by Monizzle View Post
    Yes it's a 2.0T - Is there any thing that can be done to reduce this lag?
    Registered Member Two Rings Chanabra's Avatar
    Sep 04 2008
    Dana Point, CA
    Would like an answer as well
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by kooltechie View Post
    That's odd. I experienced the total opposite when I had an A4 loaner with quattro/tiptronic. I've never experienced lag with my CVT, but with the loaner the lag was definitely there. I actually didn't know what turbo lag was until I drove the loaner..
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    You could purchase a front mount intercooler. They help supply colder air to the engine when it's warm out. The factory side mount intercoolers work to a certain point but after some time driving or sitting in traffic they will lose their ability to feed colder air into the engine causing heat soak. Heat soak causes a drop in power across the whole powerband. However, you're always going to have some lag as the car is turbo'd. The lag happens because the turbo relies on exhaust gases to spool it up. Obviously as you accellerate and gain RPM's, more air will start flowing through your exhaust and into your turbo to spool it up and create power. That's why if you give the car gas in low RPM's it feels like it gets a kick in it's pants around 2.5k and 3.5k RPM's.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Aug 27 2008
    Quote Originally Posted by Glassnpowder98 View Post
    The GSG intake would pair with that also.
    Oct 29 2005
    10speed
    San Francisco, CA
    manual transmission
    - Clint
    Mar 07 2008
    Audi A4 B7
    VA
    Manual transmissions break and then don't get warrantied
    Clint, do you do synchro replacements??
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    No it isn't. I just had a loaner Tiptronic FWD.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jul 01 2008
    2006 Audi A4
    Southern California
    Any idea on how much a GSG Intake or front mount intercooler would run you installed? The lag is very annoying and kinda embarassing if it happens when some is in your car. Almost feels like your transmission is getting ready to go out.
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by davis449 View Post
    There is no such thing as Tiptronic FWD. All FWD are CVT.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Jul 01 2008
    2006 Audi A4
    Southern California
    So I just checked the window sticker that came with the car (you know the one that lists all the standard features and options). I guess I have the Multitronic CVT (that's what the sticker said). I don't know where I got tiptronic from.
    In any case, thanks to all of you who responded I really appreciate your input.
