Results 1 to 3 of 3
    Oct 02 2008
    Newburgh
    Need some help...questions on B7 S4
    I'm looking pretty hard at a B7 S4...has everything I want but two options. I've searched the boards and didn't see anything, so...here's my questions:
    1. Can you retrofit heated seats in a B7 S4? Ballpark, any idea what it would cost?
    2. It has wood beltline trim...I'd like carbon-fiber. Can those parts be ordered? How challenging is it to swap?
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Re: Need some help...questions on B7 S4
    Don't know about the heated seats. Mine originally came from Florida so no heated seats. Wish I had them, though. As far as the CF trim, I think it's relatively easy since people do it all the time. You can get OEM which is most likely really pricey or you can get an aftermarket set. There's a guy on here Winston Podi or something like that who sells CF parts and the trim is one of his top products.
    Established Member Two Rings corstiaanw's Avatar
    Nov 09 2006
    Plano, Tx
    I know the carbon fiber is ridiculously expensive to swap. I looked for 9 months to find an S4 that had carbon because it was thousands to swap even though it was less then 400 dollars factory installed. As for the heated seats I brought my car to a company that does tint, lowering, radios that sort of thing and they installed heater elements for about $600 both front seats with a high and low setting. Not too bad works great and didn't crush the wallet.
