Results 1 to 7 of 7
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Bats caps calculator done.
    i dont have delphi anymore because my laptop crashed and i havent installed it,
    but since you guys need something i put this BATS CAPS calculator together quickly in visual basic...
    it calculates CAPS time for 4200rpm - 7500rpm
    heres the link:
    http://tinyurl.com/3ny8mw
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Dec 14 2005
    Re: Bats caps calculator done.
    bump
    1999 Subaru Outback
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Already downloaded and put it up on AW for others to use as well. Maybe ModifiedA4 will add a section to the site. Image of LOG is a must:)
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by bassed View Post
    i havent used his programs yet, but if they:
    -could read in a user perferences file
    -import the logs
    -perform the calculation
    -output html text results
    that would be orgasmic and easily implemented into the database.
    even if only the last step was doable, that would still be noice.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Nice. Any chance you could do one for 4500-7500? Sean posted asking if the starting rpm could be a little higher then 4200.
    I guess this will now allow BAT owners to get both low-mid rpm data for CAPS and mid-high rpm dat running all on one run just by starting below 3800 and finishing at 7600 rpm.
    Feb 06 2006
    '01 A4 1.8T, '01 Audi S4 Avant, '15 Dmax High Country, '01 Spec Miata #13
    Suffield, CT
    i tried it and got a value of .01... something is not right
    2001 A4 1.8t | Under Construction
    2001 S4 Avant Hybrid K04, EPL Tuned.
    2014 Touareg TDI (Hers)
    2015 Chevy 2500HD Dmax High Country
    2001 Mazda Miata Spec'd Track Whore #13
    Jul 07 2004
    socal
    Yeah it doesn't seem to be working at all. It gave me zero.
