Results 1 to 4 of 4
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    boost... 22psi in 3rd 24 psi in 5th?
    i was just checking to see where boost is at tonight and in 5th gear it was going up to 24 .. and in 6th it was going up to 25....3rd gear is at 22psi.. and i have a MBC which i (thought) i had set to 22.. i don't get it. is it because i don't have a TCD?
    -Luis
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: boost... 22psi in 3rd 24 psi in 5th?
    That's what MBCs do... they are affected by load. And a higher gear has more load.
    Boost will also be lower in 1st and 2nd.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Nov 02 2005
    S4
    VA
    so is that safe? should i go with a straight n75 valve? i can't afford to have my car go BOOM! so i'd like to know.
    -Luis
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Perfectly fine, no worries.
    Lots 'o Goodies
