Results 1 to 6 of 6
    Oct 02 2008
    florida
    maintenance info for new owner
    Just picked up an A6, 4.2, and need some info. On the way home tonight the check engine light came on, right at 74900 miles. I take it this is an indication for some sort of periodic maintenance and not a coincidence. What's needed, and where do I find the directions?
    Also, can I input my VIN# somewhere and find out what maintenance has been done, of record? I bought this from a dealer, not Audi, so I have no records.
    Anything I should be aware of? 10/02 build date, auto trans.
    thanks
    Mark
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    Re: maintenance info for new owner
    The CEL does not denote periodic maintenance, it indicates a thrown fault code. It can be a number things, it can range from an open fuel filler cap, dirty MAF, engine misfire, O2 sensor fault, etc. You will need to get the code read, either from a dealer, an independent shop, or a VAG-COM tool.
    As for maintenance performed, if your car was serviced @ an Audi dealership - your local Audi service department might have records of what was performed on your car.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    go to Autozone and get it read by them for free. Then we can help you better. The 4.2 is pretty bullitproof, so it can only be a handful of things.
    Congrats on the car. I love my 4.2
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Oct 02 2008
    florida
    Appreciate the input so far.
    Does this car also need the 75K timing belt change? If so, are there instructions posted somewhere for this? I typically do my own maintenance, so unless this requires some exotic tools and a 3 armed contortionist, I'll probably tackle the job myself.
    This morning i found a puddle of fuel under the left rear, so it looks like I have a little investigating to do this weekend. And here I thought I was buying a car I wouldn't, for once, have to mess with on a regular basis!
    thanks
    Mark
    Apr 18 2007
    ny
    Oh man that sux, you just bought it and you're having problems from day 1. Good luck with it man.
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    May have some recourse with seller. You said dealer and since he's a "merchant" by law, he may need to address the fuel puddle problem since he had to know about it....
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
