Results 1 to 24 of 24
    Registered Member Two Rings
    Feb 01 2008
    chipping a high mileage motor?
    How many miles do you guys have on your motors? I have 150k on mine all stock and i want to throw a chip at it. Bad idea? I see a friend of mine with an old turbo Volvo with 200k modding the crap out of it and beating on 350z's lol So what about our cars bad idea?
    Jun 01 2008
    Apopka, FL
    Re: chipping a high mileage motor?
    I have 110K n mine and I don't have any worries about when I go BT and more than double my stock hp.. my chipped one runs like new, burns no oil and is mechanically in good condition.. really the engine isn't the worry, it's all the dry-rotted vacuum lines, stock clutch and rubber hoses that should be checked. even with that consideration, just adding a chip shouldn't cause too much worry, unless the above are in critical condition.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    ^^^ what he said.
    if you don't have sludge, and the engine isn't making any funny noises, and everything looks ok under the hood.... go for it
    {99.5 Avant}
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    I've got 266k on my 1.8t I just had a k03 chip done and I ran a k04/pc-16 for 4k miles.
    Just do it you'll be fine.
    Cooper
    Sep 23 2007
    well theres always the problem with pushing a stock turbo with 150k miles on it
    Veteran Member Four Rings lawnferie's Avatar
    Jul 09 2008
    86 bmw r80 airhead. bmw k1200rs
    Mish/South Bend, IN
    just do it. u will love it, and wonder why you didnt do it earlier
    Was uns nicht umbringt, macht uns stärker
    lots of goodies
    B5 noggy s4
    Sep 17 2005
    Dublin
    Quote Originally Posted by mainer0311 View Post
    Cooper
    That is very impressive and almost unheard of mileage!
    170k on my 97 and waiting to get my ecu back from getting chipped :)
    2000 A4 1.8T
    1997 A4 1.8TQM
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Quote Originally Posted by onepoint8tee View Post
    Cooper
    No kidding!
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    176,xxx on a gt2871r and 26psi here
    Jun 13 2007
    2005.5 A4 2.0T 6MT
    Leesburg, VA
    I just got mine done and I'm now pushing 155K... no problems yet
    2000 A4 1.8TQM Ebony Pearl
    210K on the Clock and going...
    2005.5 A4 2.0T Quattro 6MT Moro Blue
    Heated seats. Winter calls.
    Future Plans
    B8.5 S5... at some point... or a Cayman.
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    150k on mine and the only problems I have had are the ICM and the stock clutch is quickly on it's way out...
    ...Just make sure the maintenance has been done.
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Just put a Big turbo on it, you will get used to the chip so fast haha.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Jan 17 2007
    Quote Originally Posted by prey View Post
    Sad but true
    Feb 01 2008
    eh i would bt it but idk how much longer im going to keep it. got the evo itch lol
    Apr 22 2007
    Riverbank, Ca
    150k on APR stage 3. Chipped turbo came out at 145k, It was GONE. So was the exhaust manifold... Big crack through both.
    You might have to replace your exhaust manifold and turbo, but the engine (properly cared for) should last! Keep in mind your turbo will need replacing anyways at some point.
    Feb 01 2008
    can i put a KO4 in with out changing like injectors and all that crap?
    May 22 2008
    az
    yes, the basic k04 software that is available doesn't require much else besides the turbo, but you will also want AT THE VERY LEAST a full exhaust and upgraded diverter valve.
    {99.5 Avant}
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Chipped since new in 01.5, 105K and the waste gate is starting to flutter. 3rd clutch though!
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Sep 17 2005
    Dublin
    3 clutches in 105k? Wow you must slip that thing like crazy all the time.
    2000 A4 1.8T
    1997 A4 1.8TQM
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    chipped my old a4 at 140 , car is still in the family still chipped and has like 210 on it now no turbo related problems
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Over Boost View Post
    I chipped mine @ 157K. New clutch went in at 158K, guess why. The stock clutch can last that long on stock power, but a torque spike like chipped cars do will eat one up.
    FWIW, I'm past 175K now and I still hold good vacuum and compression.
    I'd say do it.
    Dec 05 2007
    I asked this same question on here a couple months ago. I was told that if your turbo is in at least decent condition and you have good compression numbers in all 4 cylinders then there should be no issue (other than old crusty vacuum hoses). I have 116k miles on mine and chipped it maybe at 113k. There are people whom replace thier turbos with an older used one w/less miles just to be on the safe side. If that is the issue that has you shaky, then find a used turbo for maybe $150 shipped tops or rebuild your current one.
    Apr 19 2008
    215 PA
    gt28rs full big turbo setup at 150,000 mile have been running around with this setup for 10,000 and no problem!!
    Jan 04 2005
    530, California
    Well stock was repaced by dealer b4 I bought the car at 33K Then it lasted until about 90K, SB now, no more slip.
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
