Results 1 to 7 of 7
    Registered Member Two Rings kerrys914's Avatar
    Jan 31 2006
    St. Louis area
    MPG display at Idle drops 0.1mpg every 5 secs of so
    Does anyone else have this happed at idle?
    I have been getting low MPT, 230miles taking it easy.
    Seeing people getting 20+ is killing me
    Not sure if I have an issue or not somewhere in my 01.
    Cheers
    Sep 21 2008
    new braunfels
    Re: MPG display at Idle drops 0.1mpg every 5 secs of so
    tuned?
    My car doesn't seem to calculate fuel usage when sitting idle... just goes to -- I think... or sits at the previous # - every other car I had calculated it.
    But I got 370 miles on my last tank, so I'm not one to complain....
    Veteran Member Three Rings hoosierchemist's Avatar
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    How recently did you reset your average mileage? If you reset after each fill-up, then drive through town (stop-and-go), those times spent sitting still really bring down your average mileage.
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    Quote Originally Posted by kerrys914 View Post
    Cheers
    wow man thats really bad your probably running uber rich go to your tuner and ask him to lok at it ... im getting close to 30 mpg highway when conservatively driving ( never haha) but yeah man get that checked out
    cheers
    --daniel
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    that may be a little off but not much. I only get about 250miles to a tank.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Cheers
    That is about what my stg 3 TIp gets out of a tank if I drve easy, for a 6speed car you should do better, when was the last time you changed your wirfilter or plugs they may be worn/cloged and may hurt your MPG , also in cooler weather your MPG will drop some because the car will run a lil rich untill it hits operating temp , that is what mone dose, good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    I'm at about 250 miles per tank too. I just replaced the O2s and my mileage didnt change.
