Results 1 to 10 of 10
    Registered Member One Ring gilsmak's Avatar
    Sep 20 2008
    2001 S4 Light Silver
    Logansport, IN
    Help in Grand Rapids MI....
    Anyone is the GR area or nearby western mi that can help me out with a pressure test? It's on a 2001 S4. And at the same time, anyone with a garage that could assist me with pre-cat O2s?
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Re: Help in Grand Rapids MI....
    Where are you at in G.R.? I also have an S4, and can help you out.
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'm in GR, but I don't think I can really help a whole lot other than advice. It's a royal bitch, I will tell you that. I just put EGT and O2's in a customer's car last week.
    Sep 20 2008
    Logansport, IN
    I live close to downtown. I really need to check for vac. leaks and to change my IAT sensor (if I can find another one). After that, then I will get to my O2 sensors.
    I appreciate the responses guys!
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    I can help as well. Mitch and I both have FIRST HAND experience w/ those nasty O2's
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Sep 20 2008
    Logansport, IN
    Thanks guys. I guess what I am looking for is a place that I can change em and someone who knows where the drivers side one is.
    Do any of you guys have much experience with the IAT sensor?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by gilsmak View Post
    typically it's located in the throttle body. What's wrong with yours? That's not a common issue at all.
    I pulled out the driver's side O2 from the top. Some people pull the whole DP off, that's a waste of energy if you ask me.
    Sep 20 2008
    Logansport, IN
    I'm throwing a code from the IAT.
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    It sucks man. The 02's are almost impossible to get off on jackstands.
    B5 S4 6MT Stage 2+
    Sep 20 2008
    Logansport, IN
    At least its the precats that need to be changed.
