Results 1 to 4 of 4
    Oct 02 2008
    A4 1,8TQ 02, VW Typ1 2332cc
    Sweden
    S4 B6 345mm brakes on A4 1,8TQ B6 ?
    Hi !
    Have some questions about uppgrade my brakes to S4 B6 brakes 345mm.
    Have read that S4 B5 321mm brakes fits like a glove on 1,8T B6.
    Hope that anyone can answer om my questions.
    1. Does the B6 S4 calipers fit right on to my car
    2. Do i need adaptor for the calipers ?
    3. Do i need to change master cylinder to B6 S4 ? With only front brakes from S4 b6?
    4. May i change master cylinder if i change front and rear?
    5. How big wheels do i need ? have 18" on summer tires and 16" URS4 5spoke on snow.
    Hope you can help me
    Best regards
    Magnus from Sweden
    Veteran Member Two Rings StEvO's Avatar
    Apr 19 2005
    Chicago
    Re: S4 B6 345mm brakes on A4 1,8TQ B6 ?
    I have them on my 1.8T quattro.
    No additional brackets or parts are needed.
    They are completely bolt-on.
    Not sure if you'll be able to get them under your 16" wheels though.
    They fit fine under both my 18" ASA AR1s (Summer) and my 18" B6 S4 (winter).
    APR K04, APR Exhaust, RaceTec FMIC, South Bend OFE HD Clutch, Koni Coilovers, H-Sport S4 Sways, B6 S4 Brakes, 18" ASA AR1s, Neuspeed Xtreme intake, Neuspeed short shifter, APR snub mount, Stratmosphere Hyperboost HX Compact DV
    Sep 23 2006
    Houston TX
    They'll fit behind some 17s, the OEM sport wheels being one set that is ok. Otherwise you'll have to stick with 18s.
    Oct 02 2008
    Sweden
    Thank you for fast and good answers !
    I think i have to look for B5 S4 calipers so i can use my 16" S4 winter tyres.
    But 345mm brakes on front and 300mm on the back are very nice !
    Regards
    Magnus Sweden
