Results 1 to 7 of 7
    Oct 02 2008
    Calgary
    A4 1.8T code 3020 missfire on #2 cylinder
    I have a 1999 A4 1.8 T with 110K.
    It started to miss on #2 cylinder and the dealer diagnosed it as a leaking valve cover gasket that was fowling the #2 spark plug. (This was not a correct diagnosis)
    The quote was $1300 to replace the valve cover gasket, #2 coil, spark plugs and change the oil.
    I changed the valve cover gasket, coil, and plugs in about 1 hour and it ran GREAT!!
    The car ran withoutmissing a beat for about a week then #2 cylinder cut out, (misfired) again.
    I swapped out the coil with #3 cylinder, but still #2 cylinder is not firing.
    Compression is 105 PSI, fuel injectors all working, there is NO spark from #2 coil or the #3 coil, when it was swapped to #2 cylinder.
    What could the fault be?
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Re: A4 1.8T code 3020 missfire on #2 cylinder
    idk alot about the electricals but did u make sure the wiring connector for the #2 cylinder isnt corroded and the contacts are still shiny that will create a good connection? I don't know what else would cause a misfire thats not electrical?
    someone else will chime in here shortly im sure.
    good luck
    josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    IF your Ignition Amp (AKA Ignition control module) takes a crap it will normally only produce a misfire on cylinder #2. Your P0302 or VAG 16686 is what the ECM will store, it cannot sense a failure of the module/amp on it's own.
    If you have a known good part to swap in, do that for testing purposes.
    Otherwise, swap coils on #1 and #2. If the misfire moves from 2 to 1, you know the coil is at fault. If the misfire remains on #2 it could be the spark plug or the ignition amp(if you didn't replace it before).
    This is of course presuming that you have compression and fuel. AEB's aren't know to be problem child's when it comes to that though.
    I'd bet money on the ICM/ignition amp though. Start there. It's the goofy thing on top of your air box, mounted to a piece of aluminum heat sink.
    Oct 02 2008
    Calgary
    Thanks Josh, I am pretty sure that it is the Ign. control module.
    I am changing it and will let you know.
    NDK
    Oct 02 2008
    Calgary
    Thanks, I think you are right it is the Ign. control module. I ordered one and will let you know if it works.
    NDK
    Mar 15 2009
    Baltimore, MD
    So... did this fix it? :)
    I'm having the same problem on my 1.8t Jetta. I'm switching the coil packs around but it continues to misfire on Cylinder #2. (When I took it to the dealer they said to replace the valve cover gasket, which I did plus the spark plugs.)
    Dec 14 2006
    Halifax, NS, Canada
    I dont think jetta's have an icm they are like the latter audis with them built into the coilpacks.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
