Results 1 to 2 of 2
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    A.W.E. Tuning 2.7T Intercooler Update
    Our 2.7T Air to Air Intercoolers are In Stock and Ready to Ship!
    Our Complete Intercooler Kit, complete with Inlet Shrouds. Something the competition does not offer.
    Cast Endtanks featuring A.W.E. Tuning Logo.
    Why do we offer a Side Mount Intercooler design instead of a Front Mount Intercooler?
    Safety and Ease of Installation.
    On an S4, to fit an intercooler core that was larger than just the cumulative volume of both side mounted intercoolers, an RS4 bumper had to be fitted, along with significant modification to the radiator support. The amount of alterations required to fit a front mounted intercooler that had superior performance over dual side intercoolers practically made it a custom one-off installation.
    In order to make a front mount intercooler a simple bolt-in design meant seriously compromising its performance characteristics, which we were unwilling to do. To fit behind an unmodified stock S4 front bumper, the intercooler core dimensions had to be reduced significantly. Extensive cutting of the front bumper was not worth the safety compromise in our analysis, given that the vast majority of our clients drive their S4s on public roads.
    Proven Results:
    Intercooler Dyno Test Results
    Below are comparision dyno tests as performed on our Mustang MD-500-SE AWD dyno.
    AWE Tuning 2.7T intercoolers vs stock intercoolers
    (Above) Dyno comparison of stock vs AWE Tuning Intercoolers. Power is to the wheels (multiply by 1.28 for crank power). AWE Tuning Intercoolers horsepower is green line, AWE Tuning Intercoolers torque is blue line.
    (Above)Graph of measured differences between baseline and test in dyno sheet of AWE Tuning S4 Intercoolers vs. Stock. AWE Tuning 2.7T Intercoolers produced a peak increase of 18.5 ftlbs and an increase of 19.5 hp to the wheels vs. the stock intercoolers. Notice, however, that at ~3500 rpms, AWE Tuning Intercoolers produced a 24 ftlbs increase, and at 6500 rpms a 22 hp increase. That's ~31 ftlbs and 28hp gains at the crank!
    If you would like to learn more about our 2.7T Air to Air Intercoolers, please call or email us: 1-888-565-2257 or [email protected]
    You can also go directly to our website by click here:
    http://www.awe-tuning.com/page...olers
    Place your order knowing your intercoolers will be shipped immediately. Each kit comes complete with two intercoolers, AWE Tuning Inlet Shrouds (something the competition does not offer), special bracketry, and a detailed installation manual. There is some minor trimming of the body and radiator support needed to install these intercoolers.
    If you have any questions you would like to ask, please feel free. I will do my best to answer them.
    Feb 17 2004
    Sterling, VA
    Re: A.W.E. Tuning 2.7T Intercooler Update
    I'm loving mine!
    Here's a log of my intake air temps from this morning on my way to work:
    This was a 3rd gear pull at 20Psi. Ambient temp was 57F.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
