Results 1 to 28 of 28
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    plasti dip? / maybe an rs4 grille fitting non-sline without cutting
    im getting ready to buy an s4 grille to cut it down to fit my non sline.. and i want to paint it all black
    1) does plasti dip come out matte black? or gloss?? if its matte would you just recommend putting some clear coat over it to give it some shine??
    2) can i plasti dip the chrome? will it peel after being in the weather and stuff?
    3) i think i heard that some plasti dipped their chrome trim, and said that it stays on fine, and later on if you want you can easily peel it off and go back to the chrome... anyone know if this is true?
    thanks.. this should be an interesting project.. not only am i trying to cut the s4 grille down to fit, but i have never taken my bumper off before so im sure this will all take me forever
    Established Member Two Rings MDB7's Avatar
    Feb 06 2007
    Waldorf, MD
    Re: plasti dip?
    Plasti Dip comes in both Flat and gloss. I have a similiar project coming up just waiting for fog light bulbs to come in. That way I can do it all at once. I will post pics.
    2007 Black on Black S-Line B7, Revo , 30% tint, Debadged, Tinted Tails (helps with down force)
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Re: plasti dip?
    Quote Originally Posted by Bllzll View Post
    You can PlastiDip the chrome without sanding. To remove it later, simply cut a small piece into the PlastiDip and peel it all off.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Jun 09 2008
    b8
    Re: plasti dip?
    Quote Originally Posted by Pr0n View Post
    damn plasti dip is sounding like am amazing product... i really love the fact that i can peel it off later... and the fact that it comes in matte and gloss AND that you dont need to sand anything
    how much easier can it get
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: plasti dip?
    It is by far the best paint product that i have used to modify my car. if you don't like it you can take it off sooo easy.
    The usual things!!
    Resistor Install
    Mar 12 2008
    New York
    Re: plasti dip?
    I'm also planning on doing this before the winter to help protect the chrome.
    Is the consenses matte of gloss?
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    Re: plasti dip?
    i used matte on my front rings. it came out amazing. i also used plasti-dip on my HD splitter. it looks great. definitely would recommend plasti-dip
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    Re: plasti dip?
    i sprayed my entire filler with plasti dip. spraying makes a textured matte surface. there's no sense in spraying clearcoat over it and probably will not stick anyways.
    Jun 09 2008
    b8
    Re: plasti dip?
    has anyone ever used the matte??? im unsure if i should do my grille gloss or matte.. by the way my cars light silver if that matters.. i just want it to look very oem.. and the oem blackout grille seems a bit glossy
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: plasti dip?
    my can doesn't say anything about being glossy or matte, so i'm assuming it's just matte. came out damn good though, i really love the look. it's held up well for the past month or so, even on the highway i haven't seen any sign of chipping.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Feb 06 2007
    Waldorf, MD
    Re: plasti dip?
    I swear I saw it in both flat and gloss. I will try to find the link, maybe wrong though.
    Feb 16 2008
    Oakdale, MN
    Re: plasti dip?
    i have only seen it in 1 finish!
    The usual things!!
    Resistor Install
    Jun 09 2008
    b8
    Re: plasti dip?
    would i be ok to paint my rear valence with plasti dip??? or is that a bad idea?? would i need to sand it at all??
    and how does the valence come off? i heard it just pretty much pops off from some tabs
    Apr 25 2007
    MA
    Re: plasti dip?
    if you're referring to what this guy did: Clicky Click then it just might work. if you don't plan on ever having it not painted again just go ahead and do a bit of sanding before you spray. the plastidip should stick to the valence considering it stays on a lightly sanded chrome surface. i think the painted lower valence will look sick, but if for some reason plastidip doesn't work out and you've already sanded you're going to have to paint it again with something else. can't hurt to try though!
    Established Member Two Rings Eurotrash8's Avatar
    Apr 10 2008
    Calgary
    Re: plasti dip?
    I live in Canada and I went to Home Depot which is where I was told they have Plasti dip. They only stuff they have there is in a tub and NOT a spray. Is this stuff available in both?
    Where else can you buy this stuff from?
    TIA
    Apr 25 2007
    MA
    Re: plasti dip?
    yeah you want it in a spray, you won't be able to do sh*t with it in a tub!
    Jun 09 2008
    b8
    Re: plasti dip?
    Quote Originally Posted by LampyB View Post
    yea thats basically what im looking to do... i mean everyone says that i can paint my grille and chrome trim with plasti dip with no problems.. and they also say it can be done with zero sanding at all
    so the rear valence seems to be made of the same material that the grille is made of so im thinking it will work out.. i just figured since my grille is going to be black, that the valence would look better black than it would that matte greyish color
    Apr 10 2008
    Calgary
    Re: plasti dip?
    Where else can you buy this stuff from then if Home Depot in Canada only has it in a useless tub?
    Apr 25 2007
    MA
    Re: plasti dip?
    try another home depot, or a lowes...not sure if you have that store. hardware stores might have it too, just google and call around.
    Registered Member Two Rings KOU's Avatar
    Jul 30 2008
    '08 Ibis: S-Line ext & SE pack
    Re: plasti dip?
    I've been wanting to plasti-dip my s-line grille, chrome grill surround, and front rings...
    Let us know how it turns out!
    I would love to see some pics of the finished product!
    Good luck...
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    Re: plasti dip?
    here's the pic of rs4 grill on non sline bumper without cutting grill let me get the diy
    Jun 09 2008
    b8
    Re: plasti dip?
    ^ that would be amazing if i could make this s4 grille without any cutting... its looking like taking my bumper off is guna be the hardest part of my project.. i have zero idea what im doing so im hoping some DIY will get me through it without problems.. i also gotta borrow some tools
    Mar 12 2008
    New York
    Re: plasti dip?
    Whoa......so PRAUDI, is there a diy on that grill mod? I love that grill. Thanks in advance....so if this is veiwed as a hijack
    Yeah plasti-dip
    May 10 2007
    Long island
    Re: plasti dip?
    that grille looks completely jammed in there....you can see its not even making it down to the bottom. there are nice sized spaces in between
    Mar 12 2008
    New York
    Re: plasti dip?
    Missed that and agreed
    Jun 09 2008
    b8
    Re: plasti dip?
    Quote Originally Posted by jmars View Post
    Yeah plasti-dip
    lol its all good.. i got my questioned answered already.. now i want to know more about that grille fitting in a nonsline!!! i should rename the thread haha
    Jan 06 2008
    Dacia Sandero
    Arizona
    Re: plasti dip?
    Quote Originally Posted by praudi View Post
    More info on how you did this please......
    I'm contemplating buying the RS4 grille, bringing it my body shop and telling them to 'make it happen'. I love that mesh.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: plasti dip?
    Quote Originally Posted by Eurotrash8 View Post
    hardware stores, automotive stores, etc. maybe even walmart might have it.
    the tub is for dipping things. for example: you can dip the handles of your metal pliers to make them more comfortable in your hand, and get better grip.
