Results 1 to 13 of 13
    Sep 21 2008
    new braunfels
    anyone know WTF this part is? pics inside
    I was at a buddies shop, finishing up my remote start/turbo timer/alarm install and this piece was on the ground when we were all done, Obviously I was in the trunk by the vacuum module and under the steering wheel, and under the back seat... I have NO idea where it came from, almost looks like part of some clamp or something...
    Next to a AA battery for scale reference - it's made of ABS
    on the middle pic where the holes are there is lettering (upside down in that pic) that says
    " >ABS< AUN 8D5 827 347"
    "L1" is between the two holes
    and the rings are just above the "347" in the first line of text.
    Oct 02 2008
    Re: anyone know WTF this part is? pics inside
    i don't recognize it
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Genuineaudipart.com just says bumper. Its work about 14 bucks
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    Looks like a piece that would snap over the ends of the power seat rails.
    Past - '01.5 S4, APR Stage III
    Sep 21 2008
    new braunfels
    Quote Originally Posted by passatkid View Post
    where did you find that, any chance it showed you an exploded view of where the hell it went?... bumper?
    it's definitely not dirty enough to be an OUTSIDE bumper part...
    Sep 19 2006
    ND
    I just went to http://www.genuinevwaudiparts.com/pa...?siteid=214407 an type in the part number listed, I could not find a part break out but didn't look that close
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    some part to the tailgate (trunk)
    i did some searching on the part number.. found a german page..
    http://board.gulli.com/thread/905886...e-8d5-827-347/
    and one of the post translates to this
    i dont know what that one word is cause it wont translate.. but check that area.
    According to ETKA are the Anschlafpuffer for the tailgate.
    An means "on"
    puffer means "bumper"
    schlaf means "out of"
    Outside bumper for the tailgate?
    is what i presume
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Senior Member Three Rings Awwwjeez's Avatar
    Feb 11 2008
    2001 Silver S4 (stock for now)
    Santa Clara, CA
    I found one of those when I took my spare out and have no idea wtf it is. I called a friend who is a tech and sent him some pics on my cell phone and he didn't have any idea.
    Counting cards isn't illegal. It's frowned upon... like masturbating on an airplane
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    It's part of the plastic trunk liner.
    In the picture above, the trim piece I'm referring has the date stamp on it. It's the plastic piece that is right there in front of you when you open the trunk. It has about 6-8 screws holding it in. If you take that trim piece off and flip it over, you'll see the the piece you found or a spot where it should go.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    per ETKA its number 8! :) ^^Trans4m got it!
    02 Imola S4
    VA
    Do I win a prize?
    Can I get a K04? I should start a "Help me go stage III" charity
    Sep 21 2008
    new braunfels
    Quote Originally Posted by TRANS4M View Post
    Trans4M: What is that box you have, looks to be a perfect fit, or is it custom? I dig the hell out of that.
    -Z
    02 Imola S4
    VA
    It's a discontinued JL stealthbox made for the B5 A4. Need to a little bit of trimming to make it fit, but I like how it turned out.
    I think there's one in the classifieds.
