Results 1 to 40 of 47
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Timing belt change at 55k?????
    So the stealership called me and asked me to bring my car in to fix a few recalls I have neglected to take care of, in the process they checked out my timing belt due to the recent class action suit and they said it needs to be changed, is this really possible at 55k? He quoted my at almost $1400 for parts labor.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Timing belt change at 55k?????
    I replaced mine at 60k just for good measure. I operate on 60k intervals.
    -Doug
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    I'm at 92k...really need to get on that lol
    Buncha motorcycles
    Memphis, TN
    some people say it can be related to how hard you drive but im fairly tough on mine and i had 77k when i did mine and it was perfect. i would wait till at least 75k before doing it unless they can show you a heavily cracked belt
    oh and DIY for about $300 in parts/beer
    APR Stage 2/AWE Intake
    Feb 17 2005
    Sarasota, FL
    Changed mine at 57k
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by gq9 View Post
    Haha. Yes you do. In due time, as we've discussed.
    -Doug
    Senior Member Three Rings ZGSON's Avatar
    Oct 03 2007
    05 Civic EX(manual)/02 GSXR600
    Cleveland, OH area
    Mine wasn't done until 98k, and it cost around $700 at a Audi stealership. So basically my scenario was the exact opposite of yours lol.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    dont you know anyone that works on audis except the stealership, my mechanic who used to work at audi does it for 400, if you could find someone or a european shop try that it will be much cheaper
    Buncha motorcycles
    Memphis, TN
    $700 is reasonable.. $1500 is a ripoff
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    I think I will go ahead and change it soon,considering i will be moving to a remote part of arizona soon.
    Nov 07 2006
    02 A4 1.8t
    New York
    Yeah no kidding, sooner or later.
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    I change mine at 60k and it was in very good shape. My water pump however was toast (impeller separated from the shaft), so 55k is not unreasonable to change the TB, pump, tensioner, and serpentine acc. belt. It is good practice on these engines given the mileage you have.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Quote Originally Posted by 1/4 scale View Post
    x2
    the belt itself is rarely to blame. 90% of the time it is a failure of the (original plastic impeller) water pump.
    My pump was on the way out when I did my belt at 60k. It had developed a small leak and once off the car i could feel the bearings were very very bad.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Jul 11 2008
    New Hampshire
    I got mine done at 56 K and the dealership told me 1300. Got it done for 800 at a euro shop by where i live
    Oct 19 2005
    niagara
    holy cow i have 140,000 on my 04 and have never done it ahahha
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by etnies View Post
    thats funny until it snaps and your motor turns into mash potatoes
    - Clint
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    wow, how could you still be laughing?!
    km or mile for that 140k ?
    if it's 140k mile, u should really be thankful that the water pump and belt still alive and you didnt have to pay for $5000+ repair. Stealship charge $7000+.
    if it's 140k km, then really have to get it done asap or we will see your TB or Waterpump failure post here soon. see if you can still type "haha" at that time then.
    In my stealership, they only got one B6 timing belt case that it broke at 69k mile. cost to repair $7000+.
    Audi changed the schedule to 70k miles, some stealership say 60k.
    They received a lot of cases where waterpump failed before 70k.
    anwayz, I called in for 5 different audi stealerships for AVK-3.0 engine's timing belt service. All of them quote around $1400+.
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    Timing belt on an 02 should not cost more than $800 to $850 Max! Parts labor and that is everything, tensioners, water pump etc.. I changed mine at 75k even though my owners manual says not needed to 110k but thats obviously a bunch of shiat if they have sent out that recall.
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Sep 02 2008
    Boonies VA
    Yup, had that happen to me on a previous vehicle. Seriously, you will not be laughing when it snaps. The car I had it snap on was not as expensive to maintain as an Audi and it still cost me the better part of $2500 in repairs :(
    Sad part was I had been planning to get it in and replaced as part of routine maintenance anyway. Don't risk it!!
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    damn man, a 55K t-belt change is absurd. so you're going to have to replace it for the second time at around 100K? give me a break, if this really is the case audi is producing extremely cheap parts. 75K is understandable, but anything earlier than that is ridiculous IMO. if it needs to be done then go ahead and have the job done, but it really pisses me off. my uncle had a dodge minivan that went to 300K before he sold it, and the t-belt wasn't ever even changed.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    ^^^ THANK YOU. Someone who's reasonable. My car just hit 90k and I'm going to change my timing belt in the next couple weeks. I inspect it regularly and it's in perfectly fine condition.
    Those of you who change them at 50k must like spending money and tearing stuff apart.
    -Darrick
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by LampyB View Post
    It all comes down to how much risk are you willing to take?
    With the plastic impeller water pumps you're doing yourself a favor by changing the timing belt and pump out around 60k. Risk is high that the impeller will break and/or separate and you're f'd.
    With the metal impeller water pumps the risk is lower so you can probably go a longer interval.
    On my motor... Making the power its making. I am conservative with my intervals and changing things sooner rather than later. Preventative maintenance is the key.
    -Doug
    Mar 03 2004
    North Carolina
    Again ... issues related to TB failure seem to relate to faulty H20 pumps and tensioners. These parts are cheap, and in my opinion, Audi needs to hold their manufactures to higher standards, but it also has to do with design and engineering. BMW had the same problem with exploding H20 pumps (not much good after 60k of use). Fortunately they used timing chains as opposed to replaceable belts .... but if they did use belts, that also drove other accessories, then we would see the same problem on low mileage cars.
    From a design stand point, Audi 1.8T engines should have run the TB independently from the H20 pump.
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    I thought that if your TB broke before a certian mileage that audi would replace it. I have some kind of warranty on just my motor and tranny through audi. (came with my car)
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Veteran Member Three Rings misterjj2u's Avatar
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    So here's a question: does Audi offer a metal impeller water pump? Or are all of the replacements plastic?
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Mine was done 65k
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    If they told you it needs changed it probably does. You can always look at it yourself and check for excessive wear.
    Veteran Member Four Rings traf818's Avatar
    North Hollywood
    Quote Originally Posted by windyctyaudi View Post
    LOL
    -Ralph
    F10 550i M-Sport
    North Hollywood
    Oh and i did my timing belt at 49K.
    -Ralph
    F10 550i M-Sport
    Oct 15 2006
    From a few to one...
    Arlington, VA
    changed mine around 65k miles. timing belt was fine, however the water pump was leaking onto the block, which i assume would leak coolant onto the belt and make it flexible and break...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Apr 04 2007
    PHX, AZ
    We need to find out how many B6 timing belts have failed before 100K miles. I bet its only about 5% of all mfg.
    The stealership is telling you to do it at 55K miles so they can cover audi's ass and make a sale. This whole TB issue is BS IMO, does anyone have statistics, numbers? Has anyone's TB snapped on a B6 here on Audizine? I think I have seen like one maybe.
    What Remote part of AZ are you moving to?
    Paul Cordero
    [email protected]
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    I mentioned this before, but I called the dealership regarding my timing belt and the CPO warranty. I bought the car at a little over 56K. I was wondering why didn't they just change the Timing belt, as most manufacturers would when it is that close to 60K. I owned a CPO Toyota Tacoma at 50K they changed the belt. Anyway, they told me that it is not scheduled for my car until 75K. Then I asked, "If it breaks before then would the warranty cover it?"
    "Yes, also if it(the timing belt) breaks and your valves, etc. breaks with it, Audi will get you a new engine.", Audi Elkgrove Service Manager said.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Aug 23 2008
    2008 Rs4
    Yeah my buddy has a 03 a4 and his water pump failed, he messed his motor up really bad and audi gave him a new one!!!
    Jacob
    USPCLUBMEMBER#190
    Mar 03 2004
    North Carolina
    Here's a link that explains what is involved for the TB/H20 replacement. The ugly H20 pump is mine.
    http://www.audiworld.com/tech/eng99.shtml
    May 22 2007
    oakland ca
    Again, the thing that a lot of folks still do not seem to understand is that there is nothing wrong with the timing belt itself. When I did my timing job (60k), the belt itself looked almost new. No wear, no cracks, no worn teeth. The painted labels were barely worn.
    Because the water pump is in line with the rest of the timing components, AND because it is a pain in the ass to get to, you might as well do everything all at once. On many other cars the access is a bit better so you can swap out individual components (water pump etc) without doing the whole job. 300k on a belt is one thing, 300k on a water pump is a different story.
    If you feel like rolling the dice and saving a couple bucks, swap the water pump and reuse the rest. For my money, I'd go ahead and do it right.
    I have heard (but do not know for sure) that Audi changed to they metal impeller water pump in 04. Anyone confirm?
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    changed mine around 55k ish too, but paid way way less than 1400bucks
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Established Member Two Rings ggar015's Avatar
    Sep 24 2008
    2002 A4 3.0 Sport
    got mine done at around 80k
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    changed mine at 60k due to leakage and bearing noise from the water pump, the belt looked great but there is absolutely no point in reusing a $30.00 belt when you go through the labor for replacement anyhow. like everyone here is saying, its the water pump not the belt that you need to be worried about, and there have been quite a few audizine horror stories of water pump failures causing belt failure's out there. i figured i did my first at 60k, i put a metal impeller pump on, my next t-belt will probably be at 150k
    Oct 03 2007
    Cleveland, OH area
    The timing belt myth is on all cars. I just talked to my buddy last night who owns a Hyundia Santa Fe and he was told by the dealer he needs to do it at 60,000 miles. I bought my car with 97,000 miles and replaced the timing belt for the first time a month or so after I bought it.
    Dec 04 2006
    Audi A4 3.0
    Trucksville PA
    What are the Intervals on a 02 3.0? I have 91k
