Results 1 to 10 of 10
Thread: Shaking!
    Oct 01 2008
    New York
    Question Shaking!
    When driving the car between 40-60 mph and between 1800-2300 rpms, you start to feel a slight vibration. Also it only happens when stepping on the gas. It feels like it is comming from the back but now i really dont know. It happened for about a week and I brought it to the dealership and they have no idea. (standard) If anyone has any ideas that could help that would be great. It is going back in a few days to get the axle changed because someone the car passed AUDI CERTIFICATION with a torn boot!...
    Established Member Two Rings itsjeo's Avatar
    Feb 03 2008
    04 a4 3.0q 6spd
    City of Angels
    Re: Shaking!
    humm.. if you find out what the problem is let me know. i have the same problem but i've learned that raising the music helps forget about it.
    I've been to many independent audi specialists in the los angeles basin and a couple stealerships, but they all say they don't know what the problem is. some dont even notice it during test drives.
    "Man who stands on toilet is high on pot"
    -Confucius
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Re: Shaking!
    wheel balance
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: Shaking!
    Quote Originally Posted by A4donkey View Post
    wheel balance
    Could be. Thats the most common reason, but do you have aftermarket wheels or stockers?
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Oct 01 2008
    New York
    Re: Shaking!
    I have the stock rims, but they have new tires and "were" balanced. I'm going to bring them in to get rebalanced. It was driving perfect then on the last 20 miles of a 200 mile road trip it started making that sound, but only when I hit the gas so I thought it was the injectors or spark. But I will give the wheel balance a shot after the axle gets changed on Monday...Would the wheels always shake/vibrate if they werent balanced or would they shake/vibrate only when accelerating?
    Senior Member Two Rings NoUDont's Avatar
    May 16 2007
    South Florida
    Re: Shaking!
    its your axle man. had the same problem. if youve checked the balancing then its the axle.
    Apr 04 2007
    PHX, AZ
    Re: Shaking!
    What about an unbalanced driveline, bad snub mount, bad motor mounts, bad steering components? These could all cause vibrations.
    Paul Cordero
    [email protected]
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    Re: Shaking!
    make sure you get a good wheel balance..that matters alot..and it could also be a slightly bent axle..
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Shaking!
    Quote Originally Posted by trueno429 View Post
    x2, not all wheel balancers are created equal. Like most things, the machine depends on the proper maintenance also make sure that the wheels were balanced dynamically.
    Another thing, hitting a pothole, curbing your rims, etc. can all affect the balance of your wheels. Even getting a tire repaired and the tech not mounting it at the same exact position can throw the balance off.
    Most places should offer you a free check and even if they charge it would/should not be over $20 for all four.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    Re: Shaking!
    i had similar symptoms with a blown front cv joint. I was convinced it was the rear axle until we put it up on a lift to check it out.
