Originally Posted by
j2da
from what i can remember, when you lift the pedal a little bit it causes you to run a bit lean. this will cause you to pull a bit harder. worth a shot tho, go WOT and lift a tiny bit and check to see if its running leaner.
That wouldn't make sense as the throttle body should close when you let off the throttle which will cause it to run rich.
Edit: Ah, I didn't read you correctly. You said when you let off a little bit.
I actually have the same exact problem. I've been fiddling with stuff on my car to figure out the problem. I think it has to do with the software and N75 valve that is used. For some reason they don't cooperate too well. When I throw in my stock ECU, it fixes all the problems that are described in this thread.
What software are you guy using and are you using a different N75 valve than stock?
