Results 1 to 6 of 6
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    P1103 and P0420...
    I searched and found only three posts related to P1103 and I found different explanations for the code also.
    From http://www.bentleypublishers.com/tec....dtc.table.htm it says:
    - O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
    And from http://www.motorworksperformance.com/c/P and a couple posts it says:
    - MAF Sensor In Range But Higher Than Expected
    Which description is correct?
    I've been getting the cat efficiency codes for a couple months now, very annoying, my new HFC only "worked" for about 6 months before the codes started coming.
    But what's up with the P1103? Are they related? Do I need a new O2 sensor or is my cat just not doing a good enough job?
    Jan 17 2007
    Re: P1103 and P0420...
    Bump, can anybody explain code P1103 and tell me which definition is correct?
    Thank-you
    Jun 20 2007
    2012 JSW TDI
    Raleigh, NC
    its the o2 sensor code
    from your page:
    P1XXX --- MANUFACTURER CONTROLLED
    and the link at the top to vw/audi specific codes:
    http://www.motorworksperformance.com/c/VAG
    Dec 05 2007
    You need to do the fouler mod. Here is the link to the process. I myself get the P0420 code every couple of weeks and already have the foulers drilled and ready to put on. But the 02 sensor is on the bung rather snug and will need to have it installed professionally. I could not even take it off with PB Blaster and an 02 sensor remover/installation adaptor from Autozone.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by DND View Post
    .... or is my cat just not doing a good enough job?
    you answered your own question.
    Option A: do the defouler mod
    Option B: get a quality tuning company that can flash your car so that it doesn't throw those codes and your CEL. (hint: not GIAC, APR, or Neuspeed)
    Jan 17 2007
    That's what I figured but because there are two different definitions for that code I wanted to double check.
    I was also wondering if there was something wrong with the sensor because I've been getting the cat efficiency for a couple months whereas the sensor issue just showed up.
    Is it possible the sensor has been damaged by the inefficient cat?
