Results 1 to 8 of 8
Thread: 75k advice
    Jun 10 2008
    sf
    75k advice
    I about to hit 75k on my 03 a4 1.8t q 5m. At 70k I did the dealer thing, and according to the computer I don't need to hit up the dealer until 80k. But I figure I still gotta do an oil change among other things at this point. All stuff I assume I can do myself anyway. So I was wondering if you all had any advice for me on this.
    Should I do oil change (easy question)?
    What type of oil should I get (I live in New Orleans, not a ton of city driving, but no commuter highway driving either, the weather is still reasonably warm, not cold until December)?
    How much (haha dumb, I should grab the manual)?
    Recommended Oil filter replacement?
    What else should I do/fix/replace?
    Should I seafoam? If so before or after oil change? Preferred product?
    Anything else I missed here...thanks guys.
    Dec 06 2007
    Re: 75k advice
    Seafoam, or better yet AutoRx it, oil change using Total oil, and use an OEM large oil filter. then ur set.
    -Kirk
    BetaAlphaTau Member #58
    Jun 10 2008
    sf
    Re: 75k advice
    Also any sort of fuel injector or special car lube i should toss in there to get them pumps sliding up and down real good?
    Dec 06 2007
    Re: 75k advice
    seafoam.
    -Kirk
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: 75k advice
    Don't forget about the H20 pump/timing belt if have not done it already....
    Jun 10 2008
    sf
    Re: 75k advice
    Gotta save up for that. Will do at <80k.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Re: 75k advice
    seafoam it, and check your filters also
    Buncha motorcycles
    Memphis, TN
    Re: 75k advice
    when did you last do plugs?
    i would do air filter
    fuel filter (depending if/when it was last done)
    oil/filter (OEM or mobil 1 m-301 filter) i doubt you need total oil, its pricey most of us seem to get by just fine on mobil 1 0 40w
    split your can of seafoam half in the intake manifold (search for the diy) and half in the gas tank... if you want to do some in the oil, you will need to dump half the can in, drive about 50 miles then drain and put in your new oil/filter
    brake fluid flush with some motul 5.1 would do wonders as well... i was impressed by how much it helped pedal feel (probably only need this is you have never flushed fluid.. you could also do some SS lines at the same time)
    APR Stage 2/AWE Intake
