Results 1 to 7 of 7
Thread: Hazy Headlights
    Established Member Two Rings DC25S4's Avatar
    Jan 28 2008
    2007 Audi Q7 4.2 Premium S-line, 2009 Honda CBR 600RR ABS
    Alexandria, VA USA
    Angry Hazy Headlights
    I have noticed that both of my front headlight lens are becoming hazy except where the HID beams shine directly through. Took it to the dealer and one SA said it was a chemical reaction that AoA does not cover and another said it was moisture that gets in when you wash your car due to vents for heat exchange in the casing and will burn off after leaving your brights on for 30 minutes. (Tried the lights on for 45 minutes on bright with no change.)
    I am curious if this has happened to anyone else? I am about to ruffle feathers...
    07 Q7 4.2 Premium (Phantom Black Pearl) - S-line package, Lane Assist, Tow package, Roof Rack bars, DVD headrests added, switched interior to wood trim
    09 GMC Yukon Denali (Black)
    Veteran Member Three Rings iamproph's Avatar
    Jun 19 2008
    2012 Daytona Q5
    Re: Hazy Headlights
    Happens to me too. When I got the car the dealer claimed the moisture was a result of the vents and it would go away as well, but never does, it is like that 24/7. Called my local dealer and they too said they wont fix it. So I called AoA and talked to someone who said when I bring it in and make a case that it is a safety issue causing my headlights to not properly illuminate because of the buildup, they will have to replace it. Have my appointment for me 55k inspection in a week ill let you know what happens.
    Oct 11 2007
    Suburbia
    Re: Hazy Headlights
    I have a slight haze around the beam itself, I think it more has to due with pitting the housing from driving....
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Re: Hazy Headlights
    check the A6 forum -- a couple good threads (also detailing forum)
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Active Member Two Rings itnetwiz's Avatar
    Sep 28 2008
    2015 Jeep Wrangler Unlimited
    Midland Park, NJ
    Re: Hazy Headlights
    What was the outcome with the dealer? Did they replace it? I have the same problem and my car is still under main warranty.
    Sep 28 2008
    Midland Park, NJ
    Re: Hazy Headlights
    DId they replace it after you told them that?
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Re: Hazy Headlights
    My current car's driver side headlamp had moisture in it when I bought it. The car is under warranty. It was replaced.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
