Results 1 to 26 of 26
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Who here has expierence with micro polishing gear sets and cryoing them as well?
    I want to rebuild my transmission over the winter but while its out and all apart i would like to build it up a bit. Any thoughts or ideas as to what can be done to make these transmissions stronger, smoother, better? I know i want to cryo my gears for strength and REM micro polished for smoothness, are there any other things that can be done to make this tranny better??
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Three Rings ToMMyRsK04's Avatar
    Dec 26 2006
    2000 audi s4
    New York
    Re: Who here has expierence with micro polishing gear sets and cryoing them as well?
    I think all that cryo treatment is a waste of money .. wouldnt invest in that .. the stock tranny will hold really high hp as is .. I would buy the upgraded syncros/clips ect from JHM though
    bye bye AWE Stg 3+ and HeLLooOo ........
    For Sale
    - VAST Port & Polished Intake Manifold - BEST OFFER
    - Stock B5 S4Pistons/Rods/Valves/Springs/Retainers/Cams 44k on them
    - Two GT3076 Turbos
    Apr 20 2004
    Boston
    Quote Originally Posted by ToMMyRsK04 View Post
    The upgraded kit jay sells is all oem its better but not race car hero satus
    Dec 26 2006
    2000 audi s4
    New York
    Quote Originally Posted by awdbiturbo View Post
    Well I would rather spend around $1000 for his upgrade instead of a tranny like Stasis thats going to cost you $5000
    For Sale
    - Two GT3076 Turbos
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    BUMP!
    Senior Member Three Rings rcjustin's Avatar
    Aug 29 2007
    00 s4
    what do you even get thats so special from stasis?
    Silver SSP Stage 3+ S4
    Apr 07 2005
    rub n' tugs.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    im going to be rebuilding a tranny soon and plan to go with a cryo rem treatment ... its pretty expensive so i might just do it to 1-2-3 gears
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Dec 26 2006
    2000 audi s4
    New York
    Quote Originally Posted by rcjustin View Post
    Nothing.
    For Sale
    - Two GT3076 Turbos
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    ASP has cryo treated their tranny iirc on that red gt car. Call them they would know more.
    Apr 20 2004
    Boston
    Quote Originally Posted by Boris View Post
    Yes that is true mark does have his tranny pimped
    Nov 16 2006
    Boston
    did you get any quotes on how much cryo REMing everything is? or even a place willing to talk to you? i emailed a couple places just by finding them through google, but no reply - a phone call would probably be more effective with those types of companies ...
    1999 Black A4 Avant
    Apr 20 2004
    Boston
    Quote Originally Posted by DxC View Post
    I have connections with cryo and working on REM coating. I have a shop in leominster so once i find out a short drive from Boston and we could get it done together...
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    The trannys are stout in these cars. I have 130k of pure abuse on mine. My videos of launching and racing only show a fraction of what my trans has been through. My car has been stage 3 since 40k miles as well. The only thing I did was rebuild it with the contents of my kit at 89k miles.
    My transmission still shifts smoothly. However I do notice that on some rebuilds 1st gear tends to show some wear and pitting, more than any other gear. So when it is apart hardening or cryo treating would probably help reduce wear and longevity. I think the stock gears are up to 500+whp with no issues or even more if you don't beat on it hard. Also hardening tends to be a good idea when road racing since the gears and gear oil get nice and hot and used longer than normal.
    Until I take my trans apart I can't tell you how well it has held up for sure since it is quiet and still shifts good. But I would bet that the gears are pretty beat at this point.
    Bottom line, hardening and or cryo treating gears is probably NOT needed for 90+% of S4 owners from what I have personally seen.
    In my car I have sheared in half 3 front axles, twisted another and blew my rear differential to pieces internally and I still have the basically original 130k mile trans. I have had other customers break stuff, but never a trans yet (other than the 1-2 shift collar). Knock on wood.
    Hope this info and first hand experience helps with your decision.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    They can also send out your parts to get cryo treated. I may have 1st through 3rd gears done when my 1.8 trans is apart this winter.
    -Doug
    Aug 24 2005
    Lathrop, CA
    Actually all you need to do is find any local heat treating or cryo treating place and give it to them. There is no special secret, just knowing where to send it, look online and in your lcoal yellow pages. They charge you by weight as well.
    If you take it to any shop they will just be sending it to one of these places and marking it up.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by jaybquick@JHM View Post
    true, you know Mark will charge you up the ass doug
    - Clint
    Established Member Two Rings Mark@AutoSpeed's Avatar
    Jun 01 2005
    East Coast Pimpin'
    Excuse me? How about Doug calls me first and asks me about the process and costs, rather you making dumb ass comments.
    As an FYI we normally charge $1000 for the ENTIRE trans to be cryo and REM coated, keep in mind certain parts can not be REM treated, but the shafts, selecters, syncros, gears, hubs... all benefit from the process.
    If you can handle the teardown and rebuild, go for it do it yourself .
    Most people don't like to mess around with gear boxes and dont even have the proper tools to do it correctly.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Mark@AutoSpeed View Post
    fair enough, thats a good price... all I was saying is that you guys arent cheap
    - Clint
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Nothing.
    prove it or stop flapping your gums
    Dec 26 2006
    2000 audi s4
    New York
    Quote Originally Posted by JaredVL View Post
    Dont get offended because you work there .. most of your prices and products are junk
    For Sale
    - Two GT3076 Turbos
    Aug 06 2007
    Truckee, CA
    I work where?
    retard.
    I will be the first to say that a few things from stasis suck, such as streetsports if you want performance. but you are a damn fool if you think that "most of your (stasis's) prices and products are junk"
    Plus for your information the prices on their stuff hasnt been raised in like 5 years despite continually rising material and operations costs. So they have stayed more than fair on price and to say the actual products are whack shows me once again that you are a gigantic toolbag.
    Go jerk it to your pretend car, hahaha
    Feb 17 2008
    Ottawa Ont.
    LOL.
    Do you have a newsletter i can subscribe to?
    Dec 26 2006
    2000 audi s4
    New York
    I work where?
    retard.
    Their prices havent gone up in the past 5 years because thats how long theyve been overcharging ppl you moron .. $5000 for a tranny rebuild ?? You must be retarded
    And the cars not pretend stupid .. you'll know why it wasnt out when its done .. but thanks
    For Sale
    - Two GT3076 Turbos
    Aug 06 2007
    Truckee, CA
    trans rebuild is $2899, get your facts straight
    Registered Member Two Rings Knight_Rider's Avatar
    Feb 26 2008
    Go f*ck yourself!
    i know this thread/port is dead, but can yall keep beefing please?
    by far the most entertaining ish on here.
    Thanks in advance!
    I am Michael Knight, my car is K.I.T.T.- The Knights Industries Ten Thousand, my organization is F.L.A.G. I am powered by Garrett/Honeywell and GenerationJDM.
