Results 1 to 8 of 8
Thread: Wheel bolts?
    Sep 22 2008
    California
    Wheel bolts?
    What is the length of a stock wheel bolt? Is it 12mm or 14mm diameter? What length of bolt do I need if I use a 8mm spacer?
    2006 Audi A4 B7 S-Line, 2.0T, brilliant red
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Re: Wheel bolts?
    stock is typically 14x1.5 x27mm ball seat so for 8mm spacers you'd need 14x1.5 x35mm ball seat.
    Hartmann Lug bolts are available in a variety of sizes, are very high quality and inexpensive as well, you can check them out here http://shop.achtuning.com/index.asp?...ROD&ProdID=776
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Wheel bolts?
    +1
    14x1.5, 28mm useable length is stock
    Sep 22 2008
    California
    Re: Wheel bolts?
    Yeah, thanks...35mm is about right...
    Jun 14 2005
    Anaheim, CA
    Re: Wheel bolts?
    Stock is Ball Seat 14mmx1.5 Not sure what to recommend for spacers. But the person providing them should be able to help you out.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Sep 22 2008
    California
    Re: Wheel bolts?
    I purchased some longer wheel bolts, but they stop after one turn...what is wrong? Some guide said that I need 14x1.50B bolts...what does the "B" stand for? Is it the same as 14x1.50? I need some answers...
    Jun 14 2005
    Anaheim, CA
    Re: Wheel bolts?
    Hm... if they only screw on 1 turn then that must mean they are in incorrect thread pitch or the teeth are damaged some how? I had a lug nut before have the the correct pitch stamped on it but the threads were wrong.
    -Charles@VMRWheels
    www.vmrwheels.com
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: Wheel bolts?
    Quote Originally Posted by drifterv_2000 View Post
    What length are they? Sound like they're too short.
    We've got all the proper lug bolts you need for any spacer application you can think of.
