Results 1 to 7 of 7
    Sep 26 2008
    Grand Rapids
    Valve Cover Studs
    Has anyone replaced their valve cover studs on a B5 A4 1.8? Whoever replaced the valve cover gasket before me stripped a few of the threads on the studs. What is the process to replace the studs? Just twist the old ones out and twist the new ones in? Thanks
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Valve Cover Studs
    Can you run a die over the threads to clean them up or are they gone?
    Sep 26 2008
    Grand Rapids
    They look like they are pretty much gone.
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    they just unscrew out of the head like any other stud. You can put 2 nuts on them back to pack or use a stud puller. I suppose in a worst case you could try channel locks, but i'd do just about anything before doing that.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by matthai5 View Post
    Take 2 of the valve cover nuts (the ones you removed) and opposite lock them onto the stud.
    Get a size 10mm spanner and move in an anticlockwise direction with the bottom nut.
    Stud should come out nicely.
    Feb 27 2005
    North Wales, PA
    where do you get replacements?
    Aug 14 2008
    Salt Lake City, UT
    Quote Originally Posted by Issam@034 View Post
    Might not work if the stud is already stripped on the top- but i suppose one could always channel lock out the already junk thread, and use the reverse of this technique to install the good one.
    I like the stud puller sets, but for occasional use they are a bit spendy.
