Results 1 to 4 of 4
    Active Member Two Rings patman's Avatar
    Mar 16 2008
    AMG, Porsches, etc.
    OC, Socal
    Improper ABS activation, please Help
    MY ABS is kicking in & making my brakes grind when i applied the brakes at slow or fast speeds stops. I just had my tech replace all 4 Zimmerman 321mm rotors, mintex pads, front entire both axels, & even flushed/changed to Motul Motul RBF600 fluids on my Stoptech 4 pistons calipers even still have the problem? Only the brake sensor light comes on, NO abs lights on. Other threads when i searched "ÄBS" said something to check about "wheel tone" or incorrect tire size could activate abs erroneously. I'm running 18" OZ Superleggeras now on my '02 S4 avant. Had same issue when i ran stock 17" S4 wheels.
    Lastly, my tech says wait for abs lights to come on to know which side of front abs harness to possibly change & stupid abs light hasn't been activated for last 10k miles. Anyone had same issue?? TIA.
    02 996TT
    03 S600 AMG Sport
    05 E55 AMG
    11 997.2 GT3RS
    +others..
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Re: Improper ABS activation, please Help
    the issue is most likely a cracked tone ring on your axle.
    the magnetic hall effect speed sensor will notice the cracked tone ring as the wheel locking or skidding and it applies ABS.
    props to supraS4 on audiworld for discovering this
    you can also log your speed sensors in vagcom just to make sure all 4 values conform ... if 1 is not responding then you know the sensor is bad ... go slow when doing this, dont crash!
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Mar 16 2008
    AMG, Porsches, etc.
    OC, Socal
    Quote Originally Posted by DxC View Post
    Thanks DxC for help & guide!! I think & will look at my speed sensors then, becuz i changed both fronts axles few days ago so the tone ring on axles will probably be ruled out.
    02 996TT
    03 S600 AMG Sport
    05 E55 AMG
    11 997.2 GT3RS
    +others..
    Nov 16 2006
    Boston
    could be the rear axles ... which it probably is
    1999 Black A4 Avant
