Results 1 to 17 of 17
Thread: Chrome Trim
    Registered Member Two Rings Raudi 4.2's Avatar
    Oct 01 2008
    nothing
    nv
    Chrome Trim
    My chrome/aluminum (idk wtf it is) trim around the windows is kinda foggy and it wont come off... any products suggested to shine that shit up????
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 22 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Re: Chrome Trim
    Have you tried Never dull?
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Oct 01 2008
    nothing
    nv
    Re: Chrome Trim
    Quote Originally Posted by V8S4Fun View Post
    havn't tried anything yet.... i just got the car.... is never dull something thats proven to work? i mean theres really nothing that happened to the car.. its just weathered from sitting outside at the dealership... simple oxidation... i just cant rub it off...
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Re: Chrome Trim
    Try posting in the detailing forum. You will get a better, accurate response.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: Chrome Trim
    I've been using never dull for a long time on my wheels and have used it on the trim to remove the white spot it had. It can still be seen but I didn't remove it completely because it can hardly be seen the way it is now.
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: Chrome Trim
    thats because that trim is plastic....its not chrome or aluminium.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Chrome Trim
    time to black out the trim?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: Chrome Trim
    Quote Originally Posted by Maverick View Post
    thats typically my answer or order the parts from audi.
    my brother has this problem on his S4...mine doesn't seem
    to be affected. but i also noticed his mirror caps are chrome and
    mine are more of a brushed silver. chrome at all.
    at any rate...i said it was time to black them out.
    the decision becomes to go flat/matte black or
    shiny black to match the outside B-Pillar
    The RIDES:
    AMA Member
    JHMFTW!!
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re: Chrome Trim
    Asked my body shop contact how it could be done. Answer: It can't without the paint peeling. For avants, the chrome trim is sealed between the body and glass- forcing one to remove the cargo area window. Please someone prove me wrong.
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Sep 09 2008
    ireland
    Re: Chrome Trim
    i had the same problem with mine.I've done the research and its caused by strong wash products that the drive in wash guys that did my car were using.the milky/cloudy effect seems to form under the lacquer on the trims.some products seem to dull the effect by enhancing the overall shine but really the only cure is replacement trims.i know one guy who wet sanded them with 3000 grit paper followed by a dremmel tool to polish them up,then dressed with a zymol wax regularly.they look good but it was a lot of work.
    the Audi dealer agreed to replace the trims under warranty which he had to do twice to get right.it's a tricky job if you have never done it before but I'm sure an experienced body shop could do it with less fuss than the Audi tech guy that fitted mine.
    now they are all shiny again i just wash the car every weekend with meguire's hyper wash trough a power washer and foam lance and dress the trims with Werkstatt Prime Strong.
    by the way "Werkstatt Prime Strong" is very multi tasking.brilliant on every thing from exhausts too windows.
    May 03 2007
    german
    heaven/hell
    Re: Chrome Trim
    i did mine chrome trim and black them out with paint. it peels.
    I have yet to find a good vinyl tape to solve that.
    Feb 19 2011
    NSW Tenambit
    problem solved
    PROBLEM SOLVED
    ok here is the solution,I am an ex mechanic and have not been near a car for 40 years except the one I drive which I sold the other day and so ended up borrowing my sons Jetta and noticed after giving it a good clean that the condition of the chrome around the windows was awful.i heard and read people mention this as fogging and that it was chrome on plastic or perhaps even aluminium.
    Scrubbing and buffing with any conccoction will help a little but why?
    I will tell you, this is oxidisation so the simple answer is when you appy polish etc etc. you put a film on the chrome that isolates it from air but not enough to actually prevent it from reoccurring.
    The answer is simple.
    AFTER WASHING AND DRYING THE VEHICLE, and at this stage have to mention all the tech numbskulls at VW world wide who do not know the answer to this which is a really scarry thing to think about.
    Ok WD40 spray on cotton polishing cloth , wipe gently on chrome, problem gone.
    Gauranteed!!!!
    If it happens after the next wash just redo it as part of the normal detailing.
    A more permanent solution is this.
    (Oh boy I am a font of knowledge) having also worked as a paint and decoration specialists here is what you do.
    Go and buy a small artists brush and a can(not spray) of clear water based coating, you know, the one like urethane except it's not , the one you put over timber stain.
    In this case lightly coat your chrome, when it dries give it 3 coats if you like problem gone.
    Now my advice to all those VW "experts is you are not worth the money they pay you, here I am retired at 56 now 62 and am giving this solution for free.
    Would somebody from VW please ring , thank me, and send me a cheque for a million dollars for solving their 400 million dollar problem.
    0249347312 or 61249347312
    chers
    eric noack
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    Quote Originally Posted by b00st View Post
    Quite sure that our trim is aluminum. Not sure if it is coated with something or not however.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Aug 31 2010
    09 R1 Track Weapon
    Greenacres, WA
    if it's oxidized, covering it is not fixing it, you're just putting a bandaid over the top.
    Here's the fix: http://www.audizine.com/forum/showth...=aluminum+trim
    05 B6 S4 Avant 6MT
    06 Touareg V8
    09 Yam R1, full race
    71 Honda Z50 88cc (pit bike of death)
    64 Ducati Mountaineer 90 (in restore mode)
    Nov 22 2010
    2005 Audi S4, 1998 Cadillac Seville STS
    oakland county, Michigan
    how hard is it to take off, im getting a scratch painted on my car and want to do the trim and side mirrors all black
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    It's almost impossible to remove without bending/creasing.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Quote Originally Posted by thubleau View Post
    PROBLEM SOLVED
    Gauranteed!!!!
    chers
    eric noack
    going to try this.. will post results
    2019 QUANTUM GRAY S4
    Stock
    Prev
    2015 SUZUKA GRAYRS5
    2013 SUZUKA GRAY RS5
    2015 MYTHOS BLACK S4
    2008 AVUS RS4
    2004IMOLA YELLOWS4
