Originally Posted by
coran nariman
money is not a issue i have all the money put away for this project for years now. i just have been waiting to see how everyone else's set ups have ran and what not.
i am planning on doing some port and polish work, changing the pistons and rods. seals etc. like i said before i don't want to run a BT setup and definitely want to spend the money on a BAT setup. I still not sure of what software i would use, i hear that unitronics has a good 630cc file.
I hear there is no need to change the cams on this car? as it makes no difference...
any advice anything would be great.
i am leaning towards copying a setup like Shawn's. just simply making the engine stronger.
And is it worth a 2.0 stroker?
If u make the walls thinner on the cylinder block is that not worse for us as we have boosted cars=lots of pressure
thanks so much guys i know there is lots of information on the forums, But there is not much on building engines and what not. What are our choices for pistons, rods etc...
My machine shop was telling me that with pistons and rods some port work and the right tune, we can get her at 350-400 and change easy.
The right tune will go very far. The majority of the B6 builds right now are running off-the-shelf tunes and (in my opinion) is holding them back from making big power.
2.0 is more displacement. More displacement inherently is more power and it helps with off-boost power and drivability.
There are a lot of B5 builds and a special forum dedicated to it:
http://audizine.com/forum/forumdisplay.php?f=145. There are also a few B6 builds but most of them aren't really documented.
Camshafts help the engine breathe and increase mid-range and top-end power.
This is my configuration:
QED-Built 2.0L stroker
- (OEM) AMU (06A casting) block and cylinder head
- (OEM) AEG 92.8mm stroke crank
- Supertech 82.5mm bore forged pistons
- Scat forged connecting rods
- OEM main bearings
- OEM oil pump
- OEM timing belt kit w/ metal impeller water pump
- Supertech Inconel Exhaust valves
- Supertech valve guides
- OEM intake valves
- OEM hydraulic lifters
- Cat Cams 3651 camshafts
- Cat Cams adjustable cam gear
- basic valve seat grind/lap
Forced induction:
- Garrett GT2871R turbocharger
ASP GT28RS hardware kit with manifold and downpipe ceramic coated
- ASP FMIC
Tuning:
- Custom Me7 tune by ASP (currently in process)
Original build thread is here:
http://audizine.com/forum/showthread.php?t=198330
Tuning will be done in a few weeks and I'll have power figures (dyno graphs) and will be going to the track (1/4mile) to back-up those power figures.
Everyone has their own opinions on what works and what doesn't work. So far,
no one has stepped up to the plate with power figures and 1/4 mile times to back up their configurations. Its all up in the air as of today so I encourage you to search and around and do some reading before spending money.
