Results 1 to 40 of 53
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    Question So I'm About to Order K04s...
    Okay, so I decided I'm going to order a set of K04s for my car. Although I'm not going full stage 3 yet, I'm ordering these now just to have ready in case my K03s go. I rather start collecting what I need now and be prepared for when it happens, than having my turbos go, and unexpectedly spend a shitload of $ all at once.
    Now, I'm still a noob though, so I have a couple of questions. I'm basically looking for the cheapest, safest way to get them on and properly working. I won't be doing the fueling yet. I'll do that later down the road when I can afford it. I'm only looking for the necessitates at this point so I'm not w/o a car in case the K03s go out.
    I've done a bit of searching, but I'm still uncertain on a few things. From what I gathered, basically all I need would be a set of OEM K04s, the inlets, a MBC, and 5 bar FPR. Is this correct, or am I missing something? (I have APR software btw and plan to do piggies and exhaust soon)
    Also, where would be the best place to order what I need. I see so many vendors offering K04s, but as I said, I'm still new, so it's hard for me to know who to trust. I was considering ordering everything I need from VAST... how are they as a company? If you guys want to recommend other vendors as well that currently have K04s in stock, please do so.
    Remember guys, just looking to get the necessities at this point. Fueling and everything else will come later on if my K03s last me long enough to save enough $ for it.
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Jun 14 2007
    2000 S4
    Connecticut
    Re: So I'm About to Order K04s...
    check your PM's :).
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    You got it covered parts wise..and you should get a stg3- tune. Inlets you can save money buy going with GenX, 034, or someone had modified k03 inlets to work on the k04s.
    If I had to do it all over again I would wait a little bit and go single turbo or GT setup, just my opinion. Didnt JHM have some turbos in stock? Well good luck with the parts.
    Train Hard, Go Hard, But always be Humble.
    Established Member Two Rings caall99's Avatar
    Oct 02 2007
    Boston Area
    AudiSportB5S4, wanna pm me the same info?... i am in the same boat :)
    2000 Audi S4 Black/Black
    XS-Power Turbo-Back Exhaust * APR Stage 2+ V5 93 Octane * 710Ns * AWE DTS * Short Shifter * Stern Power Ring, Rear diff. mounts, snub mount
    Aug 23 2004
    2000 BMW 328i
    Quote Originally Posted by will175 View Post
    Thanks. I've heard that people run the K04s fine on stage 2 software though? Wouldn't that suffice me until I decide to go full stage 3 down the road? I figured I would just get a stage 3 tune when I do the fueling and everything else...?
    JHM is another vendor, along with SPP, that I was considering ordering from. However, VAST seemed to have everything covered in regards to the parts I would need. I don't think SPP does, but I'll look more into JHM.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by caall99 View Post
    done! check pm!
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Bimmerchop View Post
    JHM is another great company cant go wrong either way VAST/JHM
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    i liked AWE they had everything in stock minus the smic's but i had my parts in a week. everything went smooth after that. however i was not in your position. I am looking into vast for tuning though they seam to have good feedback from what ive herd +1
    '00 Nogaro Blue S4
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    EPL in CT can give you any kind of tune you need for your K04's as far as getting them get the turbo's and all the hardware at once.
    When i got K04's i was thinking teh same as you wait untill my K03's go but i said fu%k it and just did it with full fuel kit for EPl along with a custome tune . You will love it. take your time an dget all your parts IC,DP's ect, also whne the engine is out do new mounts/ timming belt , and fix any leaks
    Good luck and look forward to the grwing population of stg 3 in CT
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Aug 23 2004
    2000 BMW 328i
    Quote Originally Posted by S4_NE View Post
    Thanks. What's EPL though, and where are they located in CT? I was planning on having ICS work on my car.
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    YGPM.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    EPL is in stratford CT google them european perfromance labs .
    IMO be real carefull if you use ICS in stamford CT, They screwed me over in a parts issue last year and I have been compleatly blow off about it.
    The labor/work they did was ok work at best, but they sold me bad parts and after I figured it out, they acted like they gave a dam and wa sgoing to help me out, and then I was blow off by them. Talk to EPL and they will work to make your car come out right. They know teh 2.7T real well.
    PM if you need any details or help.
    Senior Member Three Rings dolphin3's Avatar
    Sep 25 2006
    2001.5 S4
    Connecticut
    I went to Prep with your brother check your PM's.
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    done! check pm!
    Hey pm me to audisport.
    Jun 14 2007
    2000 S4
    Connecticut
    lol no problem
    DO NOT LET ICS PERFORMANCE DO ANY WORK TO YOUR CAR MAN!
    im telling you, ive worked with them and they dont know what they are doing with the S4 and they will overcharge you up the Ahole.
    go to EPL, they know much more about the S4 and tony and the guys there are great.
    Mar 11 2008
    san diego ca
    lol no problem
    Thanks for the info buddy.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    Can I get this magical PM of the minimum parts needed for K04's when my time finally comes too ?
    My car is fast
    Aug 23 2004
    2000 BMW 328i
    I think I'll go with EPL in Stratford then...
    What do you guys have to say in regards to the cheaper, yet improved 034 Motorsport K04 inlet pipes vs OEM RS4 inlets?
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    there have been mixed reviews about the replica inlets. some say they fit, some say not perfect. OEM always fit like a glove. I guess it comes down to you if $150-200 more for OEM is worth it
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I went with OEM RS4 inlets and mine were fine as be the tech who installed them, os for teh 034 I have heard mixed but as for personal experiance I have none . 034 makes nice stuff from what people say but me I try to sticl to as much OEM AUDI stuff as I can at times for engine work outside of mods, when you think about it they were built for Audi cars so they will fit (OEM ) well from day one.
    Also to add make a check list and start from there for your parts gathering.
    Good luck amd PM me if you need any advice, have to help out local CT peeps lol
    Dec 14 2007
    Motorcycles
    Bainbridge, NY
    we should have a stage 3 checklist. I just ordered my injectors last night, i'm starting to collect parts and spread out the wallet-rape as much as i can.
    who's got the best deal on K04's?
    B6 Avant 1.8TQM - 2871RS beater. I am not a smart man.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    yea I will try to fiend my old one and post it here as for price on K04's I would just get them from who ever has them, they are kinda hard to come by right know,
    Sep 17 2008
    2001 Audi S4
    Mary Land
    I agree that getting the parts over time is a much better way to justify spending that much money, and it also wont put your wallet on a diet doing it that way, but a good stage 2+ can be better then a stage 3- (k04's without a tune) in many cases. Unless the K03's went, I think I would wait until I had all the parts, but thats just me. Just a heads up so you don't wonder why your stage 3 isn't running like you think it should. Also, some other things you may want to think about: sooner or later, brakes unfortunately, sorry to put the thought of such an expensive upgrade into play, but someone has to haha. Side mounts or a fmic, i am going to get the ER smic's but there are plenty of kits to choose from (AWE being highly recommended by many AZ'ers). Also have you done your clutch? I have no idea what all you have done or I would have more to say, but a stronger clutch is going to be a must. I am not stage 3, but I have the OEM RS4 Clutch with a VAST lightened flywheel, and thats what will be on when its stage 3.
    Dec 27 2007
    I am in the same situation too. AudiSportB5S4 could I get the same PM?
    Also, someone is selling stock RS6 turbos ... what would be required to use these? I see that ASP has an RS6 turbo kit. Could the RS6 turbos be used in the same step by step manner?
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    i'm in the middle of doing this.. can someone pm the info too?
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by jutny View Post
    http://forums.vwvortex.com/zerothread?id=4045706
    Aug 23 2004
    2000 BMW 328i
    Thanks for all the advice fellas. As far as the brakes go, I've got the stoptech st-40 kit on, so I'm good to go. Like I said though, I'm gathering these parts to have in hand JUST IN CASE my K03s go unexpectedly. If they hold up fine, of course I'll gather up all the parts needed and tune it accordingly to reap all the power benefits of going stage 3. However, right now I just want something to have ready in case I need it. I still want to work on going stage 2+ before I go stage 3 if I can. Again, it all depends on if the K03s last me long enough
    Now, I think I've narrowed it down between VAST and JHM. Which one should I go with, or should I say, which is the most complete/safest kit to go with?
    1) From Vast, I can get the K04s, the hardware kit, OEM RS4 inlets, the MBC and finally the 5.0 Bar FPR for a total of $3270.
    2) From JHM, I can get the K04s, hardware kit, OEM RS4 inlets, OEM Oil Pressure Line Kit, and Couplers/Clamps for inlets for a total of $3,181.
    So if you guys had to pick one, which one would it be? Also, would I still need to get a MBC and a 5.0 Bar FPR from VAST if I went with JHM? Keep in mind that if the K03s don't last me, I would most likely be running it off of APR stage 2 software for a little while.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    We have K-04s in stock ready to ship, $2599 for turbos or $2,899 for turbos and inlets, free shipping as well :)
    We get these directly from Borg - Warner and have not have any issues with them.
    Scroll to bottom http://shop.achtuning.com/index.asp?...arch=GO&Page=1
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by Skyler@Achtuning View Post
    Mine have been good from Achtuning ,
    Apr 25 2007
    I got my set form skyler, top notch guy.
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    Lathrop, CA
    I can get you a 5 bar regulator as well for the same price as VAST. Whatever you need I can get it.
    Thanks for the consideration.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Aug 23 2004
    2000 BMW 328i
    Quote Originally Posted by jaybquick@JHM View Post
    You've got a PM
    Aug 23 2005
    Lathrop, CA
    You've got a PM
    PM returned.
    Thanks
    Dec 14 2007
    Motorcycles
    Bainbridge, NY
    clay at CTS seems to have them for 2250 shipped, and JHM's site says $2300 (without shipping obviously). Those are the two best prices that i've found. Thanks so much to whoever linked to that Vortex thread.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Quote Originally Posted by xx_s4quattro_xx View Post
    Me too!!
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Quote Originally Posted by IamEzraM View Post
    same here
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    done! check pm!
    damn that makes 3 of us in the same boat can u pm me also.
    GIAC-X, STASIS TS,VAST,034 MS
    Oct 05 2008
    Klah
    I heard those guys are pretty cool
    Aug 23 2004
    2000 BMW 328i
    Placed my order yesterday with JHM
    Aug 23 2005
    Lathrop, CA
    Thanks. Everything will ship out tomorrow.
