Results 1 to 19 of 19
Thread: Fuel Injectors
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Fuel Injectors
    Would anybody be able to help me out here?
    I have some really soft clicking in the fuel rail
    Or the injectors that are constant but when I
    accelerate the clicking gets louder and
    matches the speed that I’m going at.
    I was thinking about getting new injectors
    Because recently I threw a code that said
    I was running too lean.
    So I pretty much have a stock car except for
    I have Hot air intake and a naca duct feeding it
    so big turbo or anything. The car has 115000
    miles so would it be a good idea to get the injectors
    and if so which ones, should I go for ones like
    42# Bosch Green Top Injectors would it be worth it
    or should I go with 630cc Deka's $188 / 4 pc
    I think maybe the fuel injectors can’t spray enough
    for the amount of air. Would it be bad to get injectors
    with higher cc?
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    help.....anyone
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Fuel Injectors
    Is your car stock?
    The last thing oyu want is to buy injectors. I also HIGHLY doubt that the injectors are causing the problem. If you like, go to Autozone and buy some Seafoam and put the whole thing into a tank of gas right before you fill up so it swirls around.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 25 2007
    Phoenix
    Re: Fuel Injectors
    The ticking is probably a lifter noise. And adding bigger injectors wont help you get power or anything without also adding more air to the combustion chamber. You will just end up running real rich.
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: Fuel Injectors
    Quote Originally Posted by im sofa king View Post
    No, the injectors would just fire at a lower duty cycle. Nothing would change.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    wow was i off track, ok so i did an oil change added more detergent to it and i still get the clicking that seems to be coming from the injectors would it be worth it to buy new oem injectors or should i just clean the ones that i have. I also tried some fuel injector cleaner thought the gas tank and i still here the clicking.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: Fuel Injectors
    injectors are supposed to make some noise.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    I don't know about that but it is an old engine 115000 miles on the old girl but the thing is when i accelerate i get this clicking sound coming from the front not sure what it is.
    it speeds up as i speed up and goes away when i stop or idle but as soon as i start accelerating it comes back.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Fuel Injectors
    you sure it is in your engine? The fact you said it totally stops at idle kinda makes me think it is not the engine...
    Jan 07 2007
    Re: Fuel Injectors
    wheel bearings?
    Jun 04 2007
    Austin/DFW, TX
    Re: Fuel Injectors
    Its not your injectors.
    My 5-Speed Swap DIY
    - B6 USP
    Jun 01 2008
    Apopka, FL
    Re: Fuel Injectors
    115K isn't old for this engine, it's more like middle-aged
    I'm confused, it stops at idle or when you're stoped, so how do you know it's comming from the fuel injectors?
    a clicking noise could be a dozen things, but as others have stated;
    wheel bearings are a know issue with the car, and most german engines have valvetrain tick to them, it's nothing bad, it's just there.
    on a F/I car, this usualy means a vacuum leak
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Re: Fuel Injectors
    This is probably waayyyy off base.
    but at 110,000 i started hearing a clicking noise when driving like you and it didn't sound as bad at idle... (found out a tooth on my timing belt was floating around) 2k miles later more teeth came off the belt and i needed a new motor...
    when was the last time the belts were changed?
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    maybe i confused you guys a bit with my poor English, let me start again ok
    the car is always making a clicking noise it's sort of soft and i traced it to the fuel rail or the injectors
    when i drive around i can here the clicking a bit louder. when i accelerate the clicking matches the acceleration (ex. tik tik tik tik tiktiktiktiktiktiktiktiktik) that was going from 2000 to 4000rpm
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    but you know post 9 has got a point maybe i have something like a baseball card making that stupid annoying noise kind of like on my bike when i was a kid. However i have made a few checks under the car and haven't seen anything.
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Fuel Injectors
    could just be lifter noise, which could make you think it is coming form the fuel rail considering its right there. Our cars have lots of valvetrain noise, if it is a soft noise that isnt very noticeable good chance it is lifter noise or something since your now saying it is ALWAYS present even at idle?
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    yeah i sort of figured that, so im not so concerned about that noise but its when i accelerate that i really here the clicking...
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    could be an exhaust leak, would that make a clicking sound when i drive and would it increase in speed as i accelerate?
    May 18 2008
    SOOOOOO Cal
    Re: Fuel Injectors
    no response. im getting scared
