Results 1 to 10 of 10
    Dec 31 2006
    boston, ma
    how to fix audi's f up
    when i removed my sparks i saw some carbon deposit on the seat...then i notice the washers were not completely compressed, so how do i clean this up safely?
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: how to fix audi's f up
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    sorry for threadjack, i got the same problem also my spark plug closes to firewall licking oil, how bad is it for long drive(700 miles)? it was licking before and i just replaced valve gaskets but its still doing it.
    Dec 31 2006
    boston, ma
    Quote Originally Posted by 04QuattroTurbo View Post
    thats for internal stuff...im talking about the part that the spark plugs sit on..you can see the seat when you remove the plugs
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by eclimax13 View Post
    you can use seafoam to clean that out as well. Put it on a shop rag or something lintless and wipe it off.
    USP Member 110
    Dec 31 2006
    boston, ma
    will it eat it away quickly?
    Aug 26 2005
    Re: how to fix Audi's f up
    That description doesn't sound like it's Audi's error. Instead, it is likely the spark plugs where not torqued properly, IE, not tight enough, when they were installed originally. The threads on the plugs, as well as the threads in the plug hole, must be clean, and lubricated using a light oil. WD 40 is good, then the plugs spun in until the plug gasket contacts the head, using fingers to turn the plug socket only. Then, if a torque wrench is not available, tighten the plugs 3/4 turn from the finger tight point, for new, never installed before plugs, and 1/2 turn for used plugs, no more. The preferred method requires a torque wrench with a suitable range scale, tightening the plugs to 22 ft lbsf, 30 Nm, A 3/8" drive TW is recommended. If the threads in the plug holes need to be cleaned, an inexpensive thread chasing tool can be purchased for this task. (Or use a threading tap, 14 mm X 1.25 mm TP) Apply some grease to the thread chase to catch any carbon particles cleaned from the threads. Use a wire brush to clean the plug threads, but don't allow the brush to touch the insulator at the firing tip. Never clean plug tips using a wire brush, if the tips are wire brushed the plugs are ruined. The brush wires will leave metallic marks on the ceramic insulator surface that is conductive and can cause ignition misfires.
    Dec 31 2006
    boston, ma
    who do you think put them in??????..
    May 21 2007
    Florida
    ^lol
    2018 Navarro Blue Q5
    Aug 26 2005
    I based my comment on my assumption that the plugs involved are not the original factory fitted OE set. No offense intended.
