well my car had been sitting since thursday night and i went to drive it a few minutes ago and this happened.
warmed up great, no missfires. once the idle settled down to 800 i began to putt down the road. came to a stop sign and continued on my way. shifted into 2nd at about 3k as per usual and no power. took it out of gear for a second stopped and tried first again. got up to 5mph and it started to misfire pretty bad so i put it in neutral and pulled over. the EPC light is now on and it was idling at exactly 1000 rpms. let it sit for a second and nothing changed. dead on at 1k rpms. turned the car off and then back on and it struggled to start and missfired pretty bad again while bouncing between 400-700rpms.
logged the car and cam up with this:
9 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 008 - Implausible Signal - Intermittent
17966 - Throttle Actuator (G186): Electrical Malfunction
P1558 - 002 - Lower Limit Exceeded
17953 - Throttle Valve Controller: Malfunction
P1545 - 002 - Lower Limit Exceeded - Intermittent
P1545 - 008 - Implausible Signal - Intermittent
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 001 - Upper Limit Exceeded
my battery has been dying a lot on me as it's an oddessey(sp?) light weight unit and i've only been driving my car sporaticlly. but today it started up fine for once. and i recently had my ECU out for the 550 file upgrade from REVO so i hope no water got into the box.
im thinking my TB might be shot. but i hope not.
im going to go do a TBA real quick and see if that helps.
any ideas guys?
thanks,
--Sean
