Results 1 to 17 of 17
    Registered Member Two Rings
    Apr 28 2008
    lorton
    How to achieve Maximum WHP and WTQ?
    I recently purchased a 2007 Audi A4 Quattro Tiptronic and from doing quite a bit of searching, I am not 100% on how I can achieve high end WHP and WTQ. I am looking for something in the area of:
    275 HP+
    310 TQ+
    both to the wheels.
    I know I would need a K04 turbo kit, but what would I need after this? I am also aware that I would need: Chip/Exhaust/CAI/FSI Pump/Test Pipe/Intercooler.
    Can anyone here, from personal experience, detail a working combination to produce such numbers? I have seen some on these boards who claim to produce this. Also, from a look at AudiTude_2.0t's posts, he claims to produce a 0-60 time of just under 5. What kind of setup could possibly allow one to achieve this?
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Re: How to achieve Maximum WHP and WTQ?
    Quote Originally Posted by briboy9989 View Post
    275 HP+
    310 TQ+
    both to the wheels.
    I have 240awhp & 277awtq with the mods listed in my signature, I got this on a mustang dyno.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by Six Speed Turbo View Post
    was that on 93 or 100 octane, as it appears you have both programs.
    Apr 28 2008
    lorton
    Very impressive! From an estimate or true measurement, where would you say you stand on a 0-60 run?
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    275 HP+
    310 TQ+
    both to the wheels.
    A KO4 Kit will get you close to 275WHP but prob more like 250WHP, usually you purchase a kit such as Stassis or APR. You get a turbo charger and the software to run it all in one kit. you then will need an exhaust and most likely a fuel pump. A intercooler upgrade is also recommended but not necessary to get this power.
    The other option is to buy a turbo kit with a larger turbo also from APR or AWE (these are not quite released yet but will be soon) This kit also comes with a turbo much larger than the Ko4 and software to run it. You will also need to purchase a fuel pump and exhaust. This setup will get you around 300+WHP.
    Feb 09 2007
    Killeen, TX
    Quote Originally Posted by thebikedoctor33 View Post
    I got those numbers on 93 octane, and those numbers were put down right after the fuel pump, FMIC, and reflash were done. The mechanic said it should put down slightly higher numbers once the car gets used to the new software and mods.
    As for my 0-60, I have no idea. The day I did the install I went to the 1/8 mile track after everything was in and my best time was a 8.901. They don't give time slips so I don't know what my trap speed was and if I remember my 60' was 1.9 something.
    Apr 28 2008
    lorton
    Quote Originally Posted by Nico View Post
    I found this AWE K04 at http://www.avalonmotorsports.com/ind...roducts_id=387 - would you recommend this? It states -
    335 crank hp and 357 crank torque when the Audi S3 intercooler and a cold air intake kit is added
    350 crank hp and 363 crank torque when the Audi S3 intercooler and a cold air intake kit on race fuel program
    - which in terms of WHP would be around 265 whp / 280 wtq w/o race fuel program.
    With a setup like this, what other modifications could I possibly add to increase the 265/280?
    Senior Member Two Rings renz609's Avatar
    Sep 29 2006
    Queens, NY
    I think that this is for transverse mounted engines(A3, GTI) rather than longtitudinally mounted(A4) so it won't work.
    2006 A4 2.0T 6MT Quattro
    Quartz/Ebony
    Premium/Technology/Navi
    Feb 09 2007
    Killeen, TX
    Quote Originally Posted by renz609 View Post
    It is definitely not for the A4 Quattro
    Apr 03 2008
    Cambridge, NY
    The new APR stage 3 kit should get you in the area of those numbers, but it has yet to be released so no one as of yet has experience with it. Also your driving a Tip, your going to have issues putting that much power through it.
    Apr 28 2008
    lorton
    Quote Originally Posted by pakratt99 View Post
    Really...? I knew that the Tiptronic wasn't built to withstand high end HP & TQ, but even 275/300+ to the wheels?? Geez..
    When is the new APR kit due to release?
    Apr 03 2008
    Cambridge, NY
    The engine is 200hp stock, thats crank hp, 30% driveline loss and your talking 140ish to the wheels. You want to put 275 to the wheels which would be a 100% increase in HP and you expect the stock tip tranny to hold that??? I don't think any stock auto tranny would take a 100% increase in hp without some form of upgrades. I don't imagine the standard would deal with the increase without at least a clutch upgrade.......
    As far as the APR kit is concerned, they won't announce a date even though they have a demo of both the Stage 3 and K04 they are bringing to shows, more than likely available next spring.
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    i am currently producing 275whp and 318wtq. see the sig for mods.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Apr 28 2008
    lorton
    Quote Originally Posted by extremesport3 View Post
    I chose 275 and 300+ as a goal for myself after seeing one of your posts a while back. How fast does this run you for a 0-60?
    Feb 09 2007
    Killeen, TX
    Very nice.
    Mar 02 2007
    Sydney, Australia
    the only current Ko4 kit availible is the Stassis for our cars. I would wait a month or so to see what the new APR KO4 kit looks like, or the new APR big turbo kit. It will be better to compare the 3. AWE should be releasing their BT kit and their KO4 kit as well soon. If you wait you get to choose the best deal.
    I didn't and got the old APR KO4 kit, I now wish I had waited as the new kits will produce more power.
    Jul 21 2004
    South Florida
    That dyno was a MAHA dyno and reads in crank horsepower. It was 195 wheel horsepower in that dyno. For a more realistic 275whp or 320+chp you'll be looking at a bigger turbo kit.
    cheers! Mike
    2018 Audi S5
    Gone-
