Results 1 to 11 of 11
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Time for new DV???
    I just changed all 4 of my coilpacks because i had misfire in cylinders one and three. Right after I got my car back I was driving at around 3k, stepped on it and it chugged for a second and then took off. It almost feels like I have a misfire and it happens atleast once each time I drive it. I remember reading something about oem DV's lagging and almost feeling like a misfire. I am wondering if it is time to get a new one, and if so which DV should I get??
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    Re: Time for new DV???
    When was the last time you changed your plugs?
    Black 04 Audi A4 1.8t
    APR Stage 2+, Koni FSD/Eibach, OEM USP Wheels
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Aug 23 2008
    2008 Rs4
    Changed them at the same time i changed the coilpacks
    Jacob
    USPCLUBMEMBER#190
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Do you have vag com? I get he same thing and i have a code for a bad DV.
    barrett
    2019 SQ5 Prestige
    Aug 23 2008
    2008 Rs4
    Will I get a cel?
    Jacob
    USPCLUBMEMBER#190
    Apr 01 2007
    houston texas
    I dont get a light on the dash, just a code is saved on the ecu. check it if you can, hit up autozone.
    barrett
    2019 SQ5 Prestige
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Is the 710N still the latest version?
    Aug 23 2008
    2008 Rs4
    I will have to check that out on my way home from work tomorrow
    Jacob
    USPCLUBMEMBER#190
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Sep 24 2005
    Anywhere
    I've been using version P with the APR stage 1 over 8000miles, it's sweet !
    Aug 26 2005
    Quote Originally Posted by A4donkey View Post
    No,the latest AFAIK, is 710P. I am running the "P" version. It has a nicer diaphragm, and better brass guides around the seat seal area. If/when the P needs replacement, I'm going with the ECS DV1.
