Results 1 to 4 of 4
    Registered Member Two Rings
    Sep 11 2008
    05 Avant 1.8t Qtip
    ABS / Traction Control light ??
    So my ABS / Traction Control light sometimes come on together. When I turn the car on and then off they turn off.
    Does this mean something? Or is it just a electical issue?
    Thanks
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Re: ABS / Traction Control light ??
    mine does this sometimes when i turn my headlights on. i just put in the hids from the autobahn exotics kit. my solution was to wait a few seconds before turning the lights on. problem solved!
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Sep 11 2008
    05 Avant 1.8t Qtip
    I have no mods done at all. I did a search and it seems a lot of people have the same problem. Seems like someone would have a salution
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    If you searched you should have come up with the answer!
    Anyways, I had the exact problem as you and it seems as though it is the brake switch that is the root of the problem. i have yet to change mine, but it has never done it since it originally happened....
    -Sami-
