Results 1 to 24 of 24
Thread: V8 vs V6 SC
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    V8 vs V6 SC
    I dont know if you guys are feeling the same way I am but to tell you the truth, I understand that the new V6 is lighter, more MPG, Produces more Torque, and is going to be tuner friendly making better gains vs the V8. But to tell you the truth Stock for Stock I think the V8 is still faster. My car pulls so hard when I mash that pedal. There is just something about the V8 that is special. The way I look at is the bi turbo and the V8 are both special cars. I think they should have went back to bi turbo or juice the V8. I guess im just mad and felt like talking about this.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    Re: V8 vs V6 SC
    How are you comparing your car to one that isn't even available to drive yet? And more importantly, why?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: V8 vs V6 SC
    Quote Originally Posted by charliemike View Post
    You have to justify your purchase somehow, right?
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: V8 vs V6 SC
    Quote Originally Posted by 40valve View Post
    I think we all do a little of that. The grass is always greener on the other side anyways. You can't always have the best. I love the V8, but a SC V6 would be nice. Either way my next car is going to be an RS4 or M3, but in the meantime I love my S4.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: V8 vs V6 SC
    The mod friendly statement keeps popping up. So let me put my thoughts on that.
    1 the ECU is Me17...each ECU has to be cracked as they all have there own encryption from Audi to stop us from trinketing...Im sure APR will be able to get around this but it is still going to be a deterrent
    2 it is FSI you may need to worry about the fuel system and if it will even let you push more Hp. Look at the 2003+1.8T's you needed to add bigger injectors to get real Hp from even the stock Turbo.
    3 most people are not going to mess with the car for a few years due to the price tag. The limit is not really going to get pushed till the demand from the consumer goes up. I think that will be several years away
    4 look at this pic. The shaft for the supercharger APEARS to go towards the back of the car. This MIGHT suggest that if you were to change the pulley it wont be a easy task
    5 Almost every one knows that the B5 is super mod friendly. But it is not like it became the power house that it is today over night. It took almost 6 years before the cars started making REAL power. With the RS6 turbos and the GT kits coming only in the past few years. Our cars are really only 3 to 4 years old. We with the supercharger in the near future are in the infancy of our performance potential
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Re: V8 vs V6 SC
    Quote Originally Posted by Justincredible View Post
    Nah the S/C nose and pulley is in the front underneath that little curve on the engine cover. There arent any pulleys in the back for the Pulley to run off of. That tube in the back is the intake.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Re: V8 vs V6 SC
    If it does everything better than our car's V8 stock for stock, then it is better stock for stock. A lot of people will say the sound and the instant grunt is what will keep them with the V8. If you are happy with your car, then good for you, but don't be so foolish to say the new engine can't be better than the current V8(not everyone does this). The car isn't out yet, so there is no telling if it is better or worse in the real world.
    I believe supercharging gives more low end grunt and turbos give more high end grunt, so... if this is true, then the supercharged V6 stock could get all that instant torque everyone wants from V8's. I believe there is no "lag" with superchargers.
    Jul 24 2008
    chicago
    Re: V8 vs V6 SC
    Quote Originally Posted by SuperAvant View Post
    Ya I found the diagram for the supercharger it is in the front. I don't like that intake tho that kinda looks hokie? Ah well it still is FSI let em try to change there fuel injectors.
    Registered Member Two Rings
    Sep 08 2008
    B7 S4 Avant
    Calgary, AB, Canada
    Re: V8 vs V6 SC
    Quote Originally Posted by cotmfk View Post
    Close...
    Centrifugal Superchargers don't make full boost until redline. This means that your max horsepower rating is not realized until your engine is screaming.
    Twin Screw Superchargers (like the one on this new S4) make near full boost at approx 1-1.2K RPM, which means you get most of your torque pretty much right away. Torque curve looks like a tabletop - this will be good, trust me.
    Turbos can be made to make near full boost at lowish RPMs, depending on turbo sizes etc.
    Turbo > Twin Screw > Centrifugal
    Jan 10 2007
    VA
    Re: V8 vs V6 SC
    Stock for Stock, the B8 S4 will be faster. It will have more torque available over a wider, flatter torque curve. It will have more torque at 1-2k rpm than the current V8 does. It will get better mpg and throw you back in your seat just as hard if not harder. Only thing you will give up is the V8 sound.
    I don't understand why a Bi-Turbo V6 and a V8 are 'special' yet a S/C V6 cannot be.
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Re: V8 vs V6 SC
    V8 will pull harder at 80+
    thats how I rape turbo I4 on the freeway...."you have a 432hp STi"..."what?"...
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Registered Member Two Rings shifty711's Avatar
    Oct 24 2007
    2004 S4 6MT
    Detroit Area
    Re: V8 vs V6 SC
    Quote Originally Posted by CHECKERED View Post
    Dude, there is no way in hell you are pulling a 400+hp Sti on the freeway.
    He was probably just messing with you, or he doesnt have 400+hp.
    Also the S4 is slow on the freeway when compared to other cars with similar 1/4 mile times.
    So, yeah 400+hp. Theres no chance man
    Aug 17 2008
    Southern NH
    Re: V8 vs V6 SC
    Quote Originally Posted by shifty711 View Post
    maybe it was stock...
    Jan 01 2008
    Long Island NY
    Re: V8 vs V6 SC
    u went from "432 HP" a very exact number to maybe it was stock. Thats a big difference. I would bet that with just a chip and catback an STI would take an S4 top end.
    Jan 01 2008
    Long Island NY
    Re: V8 vs V6 SC
    Quote Originally Posted by turbo4s View Post
    Thats a pretty strong statement for a car you haven't driven, nor has anyone else. My A4 pulls hard when i mash the pedal, doesn't mean im going to beat an RS4 or anything else.
    Since we have no driving experiences to back us up thats just go with the statistics. The B8 S4 has more Torque through the rev band, more hp available through the rev band, has two better transmission options (dsg now available), is significantly lighter, has almost 50/50 Weight distribution, has 60/40 Quattro etc... On paper the new S4 should "walk" a B6 or B7. Look at the past stock for stock. The B5 S4 was alot quicker than the C4 S4, the B6/B7 is a good amount quicker than the B5 S4, so what gives you the idea Audi is going to build a slower car than before. Obviously there not going backwards. If Audi thought that supercharging the S4 was better i think im going to trust their engineers. I have a suspision that Audi knows what there doing with this car.
    Aug 17 2008
    Southern NH
    Re: V8 vs V6 SC
    Quote Originally Posted by Auditude2.0T View Post
    u went from "432 HP" a very exact number to maybe it was stock. Thats a big difference. I would bet that with just a chip and catback an STI would take an S4 to 150.
    well the guys yelled out his window that it was 432hp, his sti did not look stock, so I’m not going to be like "show me a dyno chart" we raced from 80+ and I slowly kept pulling until 130 when he shut down, he was a car length behind
    Jan 01 2008
    Long Island NY
    Re: V8 vs V6 SC
    If that HP rating is true nice kill. On the street its all driver and you must have out driven him. Nice:)
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: V8 vs V6 SC
    +1
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    Re: V8 vs V6 SC
    Coming from a new 2001 B5 S4 and modding it. I was happy to get rid of all the turbo issues I had. The V8 S4 just runs better. Cold days hot days it doesnt seem to matter to the v8. I cant go back to a turbo v6. My next car will be a V8 or V10.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: V8 vs V6 SC
    I love the V8 motor, it has been around forever.
    smooth and powerful.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: V8 vs V6 SC
    That's some good reasoning
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    Re: V8 vs V6 SC
    Uhhh.. I've owned two STis... There is no way you came close to a 400 hp (WHP or crank hp, I don't care) STi even from a roll. My 2004 was making 400 to the wheels and my B6 S4 would get walked so hard by it the contest would be laughable. In fact, even a stock STi I bet you would barely take (the 2004 - 2007 STi = 3200 - 3300 lb car vs your 4000 lb hog) from a roll if at all. I love the V8, but the turbo 4 of the STi is pretty potent.
    If you walked him at 80 I would hazard a guess he wasn't trying or drives like a moron. Or maybe you were just joking. I assure you, unless his car was broke his was faster.
    PS - My 2007 STi with exhaust and tune ($1000 in mods) made 320whp & 380wtq on 93 pump. This in a 3300 lb car. Think about that in relation to your B6 S4 for a second....
    PSS - Maybe you were thinking of the Evo. The STi is a turbo 4 boxer engine. Not a turbo I4. The Evo is a turbo I4.... Just FYI.
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    Re: V8 vs V6 SC
    How many times are we gonna have this same conversation...all I see on the forums now a day are "new S4 versus V8"...honestly, Audi had to make the new S4 a little faster and more fuel efficient or they wouldn't sell any. It's a nice engine, there's no doubting that...completely different from the V8 though. Personally, I prefer the sound of a V8 (especially when supercharged) because it sets the car apart from most others and nearly everyone who has commented on my car tells me they love that it's a V8. But a supercharged V6 has a lot of potential, so it's for all those people looking to get better performance boosts and save a little mula on gas. The V8 is slower, that's a fact...but only by a few 10ths of a second...pick a car for the way it makes you feel when you start it up and drive it hard on roads that were made for S4s, not for straightaway 0-60 times. But that's just my opinion on the matter...
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    May 30 2007
    MA
    Re: V8 vs V6 SC
    All this talk about modability with the V6 SC - Meh. Roots blowers dont have much modability. Not nearly as much as a Centrifigual or a turbo. They generate too much stinking heat to really turn on any boost. Not to mention, controlling boost is a pain in the ass because you have to constantly switch out pulleys. While they do create a very nice torque curve, they are hindered by the ability to really be modded much beyond their current power numbers.
    Now dont get me wrong, Roots blowers also make some of the most power of any blower, but its all relative to the motor they get put on.
    2014 R8 V10 - Gated
