Results 1 to 4 of 4
    Senior Member Two Rings sjlversurfer's Avatar
    Jun 17 2004
    2019 S5 1998 A4 1967 Beetle
    Laguna Niguel, CA
    Question Need recommendations for body shop and suspension specialist PHX, AZ
    I was run off the road last night by a very large pickup truck. The entire driver side of my car is damaged due to collision with the truck, and the passenger side suspension is damaged due to being run up on the curb. I suspect that at least three, if not all four wheels are bent and/or damaged. Suspension consists of bilstein PSS9 coilovers. I had the wheels roadforce balanced, with a full alignment and corner balanced setup by an expert in San Francisco before I moved to Phoenix.
    I'm soliciting recommendations for shops who can repair the damage. My car is pearl white, so I need a body shop that has expertise in the three-stage paint process to match the color, not to mention flawless attention to detail to repair the body damage. Also looking for a wheel/suspension expert who can perform the same suspension, alignment, roadforce and corner balancing setup.
    Any suggestions are greatly appreciated. Location is not my primary concern, quality is, however, I am in the north phoenix area.
    X-post on AZAudi, general discussion forum.
    Thanks
    Sep 20 2008
    Silver '07 S4 DTM
    Phoenix, AZ
    Re: Need recommendations for body shop and suspension specialist PHX, AZ
    I just had my car repaired by Scottsdale Paint & Body (350 N Hayden Rd, Scottsdale 85257 480/941 8800) after she had a run-in with some random drunk guys. They are Audi-Certified and are owned by Penske which also owns the two Audi dealerships in the Phoenix Metro area. Not cheap, but they did good work on my poor baby. As for the suspension work, I wish I had a suggestion. I just got my S4 2 months ago. Best of luck wherever you go...
    Established Member Two Rings androidS4's Avatar
    Jul 21 2008
    07 S4
    Tempe, AZ
    Sorry to hear that. I hope you and your car are OK.
    the guys on the Vortex put together a comprehensive list a while back and it should help a little for Audi too.
    http://forums.vwvortex.com/zerothread?id=2427403
    Best of luck.
    Jun 17 2004
    Laguna Niguel, CA
    right on, thanks. the vortex list will be a handy reference in the future. much appreciated.
