I am so fvkcing fed up of this smoking problem with my car. I have thrown a full year of time at this car and an ungodly amount of money, and all I have to claim is a car that consumes a quart of oil a week and creates enough smoke to clear out a KISS concert.
Here is a brief recap of what was done to the engine:
2mm over bore with the correct hone
custom Diamond pistons
Total seal, chromium plated pistons rings (gaps are correct)
scat rods
calico main and rod bearings
arp main studs
all new seals and gaskets in bottom end
8 new exhaust valves
8 new exhaust valve guides
all new seals and gaskets in head including valve guide seals
NO HEAD WORK DONE besides cutting the valve seats
Engine has about 1700 miles on it now. Smoking has not gotten better nor has it gotten worse.
Compression test puts all 4 cylinders between 166-175 psi. This was done on a cold engine, need to perform on a hot engine still.
Irridium plugs have lots of carbon build up on them now. Brand new plugs.
Engine consumes about a quart of oil every 400-500 miles
BLUE smoke comes out of exhaust after car warms up and idles. Under accelartion and/or WOT no smoke is apparent. When car comes to a stop and then idles again, smoke will start. Car will only smoke when it has idled for 10-20 seconds. Smoke varies from a lot to a little and usually doesnt depend on anything.
I just put in a DIY catch can, similar to what FRED2k4 did using an air compressor filter. this was a temp project i installed to see if it fixed it, it DID NOT.
I checked all PCV lines for buildup and there was none.
I had intake manifold off and monitored valves while car was parked for a few days, there didn't seem to be any apparent oil leaking down the valves.
I have asked numerous local audi club guys, audi techs, audi mechanics, even the jerk who built my engine. No one has a definite answer, but maybe thats because you won't know until the engine comes out.
If you can't tell already I do not want to pull the engine again.
My questions:
What is the possibility that the oil ring is causing blow by? Do these rings need to seat also? Could it not be scraping the oil back down into the pan?
What is the possibility that there is an exhaust valve guide seal that wasn't installed correclty and leaking down? If i take the exhaust manifold off, would I be able to see the oil leaking if the car sits for a few day like this?
What is the possibility the turbo is blown and somehow getting oil back into the combustion chamber? I check intercooler and intake lines and there isn't massive amounts of oil, just enough to make your fingers shiny slightly.
At this point im desperate!!! I have considered blowing the car up numerous times.. lol its kicking my ass!!!!!!!
thanks for reading/looking and i appreciate all and any input.
-josh
