Results 1 to 15 of 15
Thread: OBD-II Readers
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    OBD-II Readers
    Has anyone ever experimented with one of these in the car? I know its rather lame but I'm a gadget junky. I put gauges in my last car, and I expect the "we drive V8's>no gauges" and the "don't be a ricer". Thinking maybe putting it in the ashtray
    http://www.apexi-usa.com/product_ele...=250&pageNum=1
    http://www.dashhawk.com/features.html
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Marin, Ca
    Re: OBD-II Readers
    Just get a Vag-Com from Ross Tech... more useful, and you can use it after you sell that car.
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: OBD-II Readers
    Or get an iPhone and download Rev when it comes out in full version, and buy the OBD hookup.
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re: OBD-II Readers
    The VagCom is bit too intense for me. While I agree its a great tool, I'm looking for something small and easy to read. Both the DashHawk and iMoni allow for up to 7 parameters to be viewed at once. Does anyone now if the required ISO14230 OBD-II is in our cars?
    Oct 11 2007
    Suburbia
    Re: OBD-II Readers
    I'd be interested too, would like to see if software has done anything for me.... for 300$ that Dashhawk looks pretty great. Anyone have it?
    Senior Member Two Rings hayasa's Avatar
    Aug 25 2008
    Re: OBD-II Readers
    http://www.dashdaq.com/
    How about that bad-boy?! Might be a bit over the top, though.
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Re: OBD-II Readers
    how about www.scangauge.com
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    Re: OBD-II Readers
    If you have a Pocket PC this is a pretty cool program, you just need to buy a cheap ebay OBD cable and a gender bender from Radioshack, and it connects to your sync cable. It's great for reading and erasing codes, doing TBAs, etc.
    http://www.arlab.it/vc/main.html
    Aug 25 2008
    Re: OBD-II Readers
    Quote Originally Posted by UGwagen View Post
    Just bought that one. It works very well and looks good since I mounted it above the steering column. Some interesting features like sending commands to the ECU and reading vehicle-specific messages are there but I haven't explored them too much. The thing even somehow calculates HP, or at least reads it somehow from the ECU. I tried to get the VW-specific codes for the auto tranny temp to work but I think the Audi ones are different b/c it didn't work...
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re: OBD-II Readers
    Quote Originally Posted by hayasa View Post
    Overall are you happy with the unit? Have any pics of it installed?
    Aug 25 2008
    Re: OBD-II Readers
    Not my car, but looks like this:
    http://www.scangauge.com/products/sg...G_3212_M.shtml
    I need to drive around a bit more before I make up my mind. I like the digital speedo and being able to read/clear codes, but if I can get the hp meter working and the tranny temp to work, it would be a home run.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: OBD-II Readers
    hey look, most of that data is available...ON THE GAUGE CLUSTER
    Aug 25 2008
    Re: OBD-II Readers
    Umm, no, not on my car. Here are a few things that it can display, stock:
    Battery Voltage
    Coolant Temperature
    Intake Air Temperature
    Manifold Pressure
    Engine Load
    Throttle Position
    Ignition Timing
    Open/Closed Loop
    Additional stuff, depending on car:
    http://www.scangauge.com/support/pdfs/XGAUGE.pdf
    Mar 09 2005
    Santa Clara, CA
    Re: OBD-II Readers
    looks like a gimmick to me
    Aug 25 2008
    Re: OBD-II Readers
    Ok, so a few observations since I drove around with the thing today. Nothing earth-shattering, but interesting (to me at least):
    1. The car gets hot fast, but cools very well. Sitting there in traffic the water temp rose to 209 and fan didn't kick on yet, but cooled to 195 after driving at speed for a few moments. Got it down to 191 after a brief distance. Our triple radiators really do their thing well.
    2. The stock intake is pretty good at getting cold air. Intake temps were between 4 and 11 deg F over ambient, which is pretty good. I'd hate to see the intake temps on a shorty aftermarket one...
    3. Got the HP gauge working. I find myself staring at the thing as I'm trying various levels of throttle...very dangerous. However, in the name of science, I did go full WOT on the highway this morning. It read 351 HP max, meaning there is some "wiggle room" on the sensors, or my car was reflashed (doubt it even though I bought it used with 2K miles on it), or it is using some sort of weird calculation to derive the HP value. Since it is only reading the output of the ECU, I'm guessing the first. Anyway, I guess it might be good for baseline info before doing mods.
